Old 10-Mar-2004, 11:10   #1
bazzer sps bazzer sps is offline
Forward Facing Speed Camera\'s Clarification
I got flashed last night by a forward facing speed camera last night doing 55mph in a 50mph (in the car) but it only flashed once are they meant flash twice or is that just wishfull thinking? The other point was a car overtook me prior to the camera going faster but did not get flashed.Does anyone know what the speed tolerence is and how long do i have to wait before i know if i have been knicked? Yours p!!!! off
Old 10-Mar-2004, 11:19   #2
I thought that at first but it was on the nearside.
Old 10-Mar-2004, 11:41   #3
keith_mann1959 keith_mann1959 is offline
Bikes: ST4S
keith_mann1959's Avatar
Mood: Finally gotten over the 748R getting stolen thing. Actually, no i haven't !
I didn't think they could flash your face at night. How dangerous is that.
Old 10-Mar-2004, 11:46   #4
The flash was a subdued the lens has a dark tint during day light hours.There were none of the normal lines in the road only a double strip very close to the camera,prosumably it measures the distance v the time taken to cross. Still anoyed that its happened
Old 10-Mar-2004, 12:23   #5
There are two main types of speed camera commonly seen on UK roads,
TruVelo Combi S, a camera unit that can monitor both speed limits and red lights It looks like a cross between the grey GATSO box and a traffic light. The main pole is grey, with the outrigger painted blue. The camera box has two circular holes in the front of it and faces oncoming traffic. The red/purple coloured 'hole' is actually an infra-red flash which means that it flashes, but you don't see it because your eyes aren't tuned to see infra-red. (The flash has a power of 360 Joules and can cycle in half a second - which means 2 pictures per second). The camera film, on the other hand, is very sensitive to red in an image, and the reflected red light from an IR flash provides more than enough image detail. The system uses Truvelo's MPC (Multi Piezo Circuit) speed measuring instrument and a 35mm camera. One system, installed in temporary or permanent sites, can photograph speeding vehicles or vehicles jumping a red light. A single front photograph, taken just after the vehicle has crossed the piezo sensors used for speed measurement, includes all the secondary check information needed for reliable operation. Piezo sensors have the distinct advantage over radar or other speed measuring equipment, in that they are very efficient in high traffic volumes and cannot be detected by any of the detection devices currently on the market. The Multi Piezo Circuit can either be buried in the road, or laid across it as rubber strips for a temporary setup, so watch.
The other main type is the GATSO which is named after the 1953 Monte Carlo Ralley winner and Indonesian immigrant to Holland, Maurice Gatsonīdes, who invented them. They are currently manufactured by Gatsometer BV., also in the Netherlands. The speed of a vehicle passing the unit is measured using a wide band Ka radar emitted from the front of the camera (the rectangular plate) in a 5o beam across the road, at an angle of 20o to the road. Ka-band radar (also known as photoradar) emits in a frequency range of 33.4000-36.000GHz. It measures your speed and if you're travelling above a pre-determined limit, trips the camera which in turn takes two photos of the back of your car - hence two flashes. It takes two so that the speed information superimposed on the resulting photographs can be manually double checked by calculating the distance the car has moved between pictures. As the pictures are taken half a second apart, and there are markings on the road at 2 metre intervals then the speed can be calculated.
This method is also used to confirm which vehicle is the target. If you contest the allegation on the grounds that "someone faster was overtaking me", a quick check of the photos reveals relatively which car has travelled further between them.
The actual radar unit takes between three and four hundred readings of a single vehicle as it passes through the beam. Within these readings, the variation in measured speed must not be more than 2mph. If it is, the radar unit aborts the test. The unit can also differentiate between large vehicles and cars by the amount of radar return, so a lower activation threshold can be set for large goods vehicles and coaches. This explains why sometimes you see a truck that is doing 70mph on a dual carriageway trip a camera when a car at the same speed does not - it has registered that the truck was going too fast (trucks are limited in top speed).
Most GATSOs are tuned slightly above the ACPO guidelines This is a very rough estimate, but it means that theoretically a GATSO in a 30mph zone will only register vehicles travelling at 35mph or more. Of course this is all tuneable by the officer who sets the camera, but those are the guidelines. This is to take account of the number of cases that would otherwise come back with people complaining that "my speedo said 30mph" and suchlike.
Old 10-Mar-2004, 16:55   #6
Rockhopper,Thats a real thorough reply thanks for that,its a real education belonging to DSC!
The only thing not answered is how long do i wait to find out if i've been nicked,i have been told its 14 days is that correct?
Old 10-Mar-2004, 17:35   #7
I think its 14 working days if they dont give a ticket there and then but they are allowed a couple of days grace as well!
To sumarise my other post, Gatsos flash twice and are mostly rearward facing. There are a very small number of forward facing ones though. Truevelo cameras dont flash but only take one picture.
Old 10-Mar-2004, 17:43   #8
DSC Member MJS MJS is offline
Bikes: None at the moment
MJS's Avatar
Mood: Feeling old...
The Police have to issue the NIP within 14 days, but they only have to post it within the 14 day period, and only then to the registered owner of the vehicle, so allow a few days over the 2 weeks for the post, and plenty more if you drive a company car or hire car.
Old 10-Mar-2004, 17:50   #9
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
what about these vans they have then.
i went past one of these on the bike and got clocked at 38mph in a 30.
as a motorist had flashed me further up the road i was reasonably sure that i wasn't going that fast.
was wondering weather the cameras used are accurate on the very curved front of a bike.
tried to get information from the police themselves but could not get a proper reply.
the only way to see the photos or any other evidence is to go to court i was told.
bearing in mind that i had no way of proving i was not speeding i just accepted the fixed penalty
i know i was doing 30 through the village but was not sure if id got my speed down before i passed the 30 sign.
Old 10-Mar-2004, 19:19   #10
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
interesting subject.
i went to an open day orginised by a local Raf air field and eveybody was able to do a sprint down the airstrip, the Mp´s were unable to get a fix on the small frontal area of a motorcycle and had to call the speed reading off. but im not sure which equipment they were using (didn´t want to ask too many questions )
second point - i hate the fact in the UK you only see the photo evidence in court!
over here you get a great little pic every time just so you can see how stupid you look when driving a car
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:46.
