Old 13-Mar-2004, 22:58
Col996s's Avatar
Col996s Col996s is offline
Bikes: 996S
Battery charging
Went to start the 996 today, after about three weeks and it would not fire up, just kept spinning the starter motor. After panicing and then looking up previous threads on this subject I jumped across from my car battery and she started.
I do not have an Optimate (a good investment me thinks) only a 6 amp car battery charger. I have removed the battery but does any one know if it is wise to use such a car charger?
I have a Datatool Veto Evo alarm so this is probably the cause of the discharge.
When I connect the battery back will the alarm sort it's self out without any problems?
Old 14-Mar-2004, 08:20
Nigel Booker's Avatar
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Had the same problem with mine after being left at the repairers for 3 months. The optimate just wouldn,t charge the battery at all. I used a car battery charger just to give it an initial kick and then put it back on the optimate.
Hope this helps.
Old 14-Mar-2004, 09:26
Mood: Avatar what Avatar
Yep had the same problem with my alarm draining the battery bought an optimate no problem since.
Old 14-Mar-2004, 14:56
rcgbob44's Avatar
Optimate, Optimate..................yes you guessed!.Optimate.
I keep one on the Duke and one on the Jota!
Old 14-Mar-2004, 16:11
what if you dont have power in the garage?? Any suggestions?
Old 14-Mar-2004, 17:39
doogalman's Avatar
Fire the bike up every week and bring it up to temp. alternativly get out on the bike.
Old 14-Mar-2004, 18:45
yellow916 yellow916 is offline
If the alarm plays up when you re-charge the batery, drop me a U2U - I've had that problem.
Andrew
Old 14-Mar-2004, 19:01
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
no power in the garadge
buy an extension lead
  #9
Old 14-Mar-2004, 21:16
BDG's Avatar
BDG BDG is offline
No power in garage
Just plug into the closest streetlight, its cheaper
  #10
Old 14-Mar-2004, 21:42
rcgbob44's Avatar
No power in the garage!!
Simply use one of ones other garages!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:57.
