Old 14-Mar-2004, 13:02   #1
Totto Totto is offline
Ventura laggage ?
Just bought a Ventura laggage rack/bag , for the sumer to (hopefuuly ) do a bit of touring ,
Is there anything to watch out for whilst fitting/using or is it as good as it claims ??
Old 14-Mar-2004, 14:02   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Supposed to be the dogs, mate of mine did a Nick Sander's Round the World trip with his, lashed spare tyres to it an all sorts. He can't praise it enough. Needless to say, I have a set for the 888 Summer hols to France.
Only downside is lack of waterproofing. I was goint to spray mine with some jollop and bag all the stuff inside.
Regards,
Rob
Old 14-Mar-2004, 19:44   #3
Got a set myself a few years ago having been peeved with carrying rucksacks, and I should have got one sooner - brilliant piece of kit.
Just watch the paint on the seat unit if you have the bag facing inwards - put some tape on the seat unit to stop it marking and rubbing the paint off.
Old 14-Mar-2004, 21:12   #4
BDG BDG is offline
BDG's Avatar
Works a treat and doesn't really affect handling if bag is placed over rear seat.
Only downside is when bag is removed at night your bike will look like a scooter from Quadraphenia if you leave the top bracket in place.
Pretty easy to fit.
Old 14-Mar-2004, 23:01   #5
Mood: aving a laff
Trev
Only problem I had was clearance of the near side pipework for the 50mm cans when fitting but a minute with the grinder and a black touch up stick sorted that.
I had mine rear facing when we came over to yours and only problem was keeping the front wheel down.
Excellent piece of kit and it did not leak even when I went to Hollland in the P******g rain for a week, best luggage I have tried on the Duke as with the proper use of Duct tape, as mentioned by Anthonye, you dont get no scratches.
Also check the clearance between the bottom of the seat unit and L brackets you need to fit, might be worth extra tape here too????
See you when you get over here
Old 15-Mar-2004, 09:53   #6
I you have problems with the L-brackets (the side bits) touching either the seat unit or exhausts, then you need to use the spacers provided to move these further out.
The kit comes with an assortedment of different thickness washers so you should be able to get it perfect.
The distance between the mounting points on the brackets can also be adjusted in the same way.
Mine fits fine with 50mm Termigs and a genuine Ducati single seat.
Old 15-Mar-2004, 12:19   #7
Yella , was hoping to make it over for the DSC track day but my babbysitter went & booked her hols that week !!!
Only got 45mm tremis on my bike !
Thatnks so far hupe to get the stuff maybe late this week early next !
Will let you know how it goes
Old 15-Mar-2004, 22:08   #8
Mood: aving a laff
Only 45's Trev, you dont say
Ant
It was the front bracket that touched the near side pipe and to space it round the pipe would have needed an inch spacer
Works great now I have the standard pipes and cans back on her, sounds S}!$£ though
Old 16-Mar-2004, 09:43   #9
Hmmm ... that doesn't sound right! Are you sure your pipes were fitted correctly? It may just be they weren't seated right and in swapping them over they now fit correctly... but then I'm sure you've tried that.
Old 17-Mar-2004, 06:39   #10
Mood: aving a laff
Once or twice, once or twice
All said the thing is superb and well worth the hassles, if any, when fitting.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:13.
