Old 14-Mar-2004, 17:11   #1
DMC DMC is offline
Mood: Perky
Is a 749 petrol tank exactly the same as a 749S?
You can move the seat/tank position on the S, but I don't know if that means the tank fittings etc. are different?
Old 14-Mar-2004, 21:08   #2
LesPaul LesPaul is offline
LesPaul's Avatar
Mood: Not sure
You can only change the seat position on the single seat 749S. There are 3 positions you can choose from as the subframe is different on the Monoposto.
Darren
Old 14-Mar-2004, 21:28   #3
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
DMC The tank is the same on the 749s... Its only the subframe thats changed and the rear panels if you have a bip or mono.You can interchange between the two so you can have seat adjustment on the mono...... Hope this helps.... Dave
Old 15-Mar-2004, 09:36   #4
DMC DMC is offline
Mood: Perky
Cheers.
I just wanted to check. I've just bought a second hand tank to go with my track bodywork.
Now I just need to get it sprayed up like the Breil Supersport 749R...... mmmmmm.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
