Alarms and Related Security
Old 16-Mar-2004, 18:24   #1
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Spyball sensitivity ?
Moved the bike yesterday and although the alarm was on it did'nt set the alarm of. Today whislt still cleaning it from Sundays ride out I notice above the lower coolant tank a flat box lying loose but connected to the wiring harness. As soon as I lifted it "all hell broke loose" and I nearly went deaf with the alarm screaming in my ear. The Alarm fitted is a Spyball Patriot
Question. Should this box be fixed to some thing and what position should it be in i.e. Flat, horizontal,upright,vertical any one have any idea's . Thanks 4D
Old 16-Mar-2004, 22:03   #2
The position/attitude won't matter too much Fordie, but it does need fastening down.
The usual place for Spyballs is the tubing that runs across the frame, between the throttle bodies just above the coolant overflow catch tank.
Tie it up with a couple of cable ties.
Old 16-Mar-2004, 23:01   #3
Fordie's Avatar
Many thanks Neil, Ill tie it up as you say. Regards 4D
Old 17-Mar-2004, 00:09   #4
Dibble
its actually a hearing test for older riders 4D
Old 17-Mar-2004, 08:24   #5
Fordie's Avatar
Can you repeat that Dibbs I can't hear a thing. 4D
Old 17-Mar-2004, 14:32   #6
It'll be the same again from the missus if you're late home on Mothers Day
[Edited on 17-3-2004 by Jools]
Old 17-Mar-2004, 16:09   #7
Fordie's Avatar
4D
Old 17-Mar-2004, 16:58   #8
Dibble
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:33.
