Old 17-Jan-2020, 16:14   #1
Red-Duc Red-Duc is offline
Red-Duc's Avatar
What oil to use
Not been on here for many years as stopped riding my SL nearly 7 years ago, Its been sat in the garage for that long and not moved. Decided I should see if it will start so I thought I would ask whats a decent oil to buy these days as want to change it before I attempt to start it.
Old 17-Jan-2020, 18:14   #2
Avarmstrong81 Avarmstrong81 is offline
Bikes: Ducati 1299 Panigale, Ducati 999
Avarmstrong81's Avatar
Check the owners manual but typically 10W40 grade. I would strongly recommend fully synthetic over part synthetic or mineral oil, there is a huge difference in performance at temperature. Also select a major brand such as Castrol, Mobil or Shell. I work in the oil and gas industry and there is significant research out into the additives such as anti corrosion, anti foam, high temperature performance, anti-oxidation, film technology, detergent, anti-wear and many more. The engine oil has to endure harsh conditions, temperature, pressure and still protect internal components in the combustion chamber, sump, big end bearings, cams, valves even clutch (if wet clutch) and gearbox transmission. Pretty impressive really. The engine lube oil also contains some substances which deteriorate over time so it is important to change even if your bike has not done any miles. Castrol Power 1 is my choice, Ducati OEM recommend Shell. Also worth running the engine until warm then draining all oil from the sump, not sucking out from the top like dealers do. This way you ensure any particulates are drained. Then flush with either flushing oil or new oil. Ensure the filter is changed as well. Unless you have water in the existing oil, running it to get the engine warm will help drain it properly. If the bike has not ran in years can you put it on a paddock stand and put the bike into 6th gear and bar over the engine by hand by turning the rear wheel? This way you will not cause any catastrophic damage and will get the internals moving.
Motorcycle engines are highly tuned, higher revving and have tighter tolerances than car engines, all the more worth doing quality regular oil changes. Hope this helps.
Old 17-Jan-2020, 20:19   #3
Red-Duc's Avatar
The bike has Motul 300v 15W 50 in it that is over 7 years old, so Im going to drain that out before trying to start it as all the oil will have drained into the sump. I just wanted to see which oil was the most popular now for the bikes.
Old 18-Jan-2020, 12:02   #4
Please dont even think of trying to start it without changing the belts first...
Old 18-Jan-2020, 16:53   #5
Red-Duc's Avatar
Thanks, did belts and shims last week
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:23.
