Old 24-Jan-2020, 17:55   #1
Avarmstrong81 Avarmstrong81 is offline
Bikes: Ducati 1299 Panigale, Ducati 999
Avarmstrong81's Avatar
Question 1299 rear shock linkage bolt replacement
I am in the process of upgrading all fastenings on my 1299 to A4-80 316 stainless steel. For the vast majority of bolts A4-70 or A4-80 is sufficient, there are only a few critical high tensile bolts such as front brake calliper bolts which need to be equivalent to grade 10.9 or 12.8.
The rear shock linkage bolts (2 off M10 x 1.25 x 46mm long cap heads) - are these grade 5 8.8 bolts? If so upgrading to A4-80 may not have significantly high tensile strength. Torque value is 45Nm. These two bolts are located on the triangular rear shock half rocket arm.
Options are:
- upgrade to A4-80 316 stainless steel if these have sufficient high tensile strength
- upgrade to titanium (probolt equivalent at higher cost)
- leave alone, the existing bolts are not yet corroded.
Any advice?
Old 27-Jan-2020, 12:01   #2
I would go titanium as you know it will be strong enough, it's blingy and you won't have to worry.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:01.
