Old 23-Mar-2004, 17:52   #1
DJ Tera DJ Tera is offline
chain removal
is there anyway i can get the chain off the bike without any special tools?
I have a new chain n sprocket set - but cant figure out how to get the old one off - theres nowhere for me to loop it over
Old 23-Mar-2004, 18:00   #2
Felix Felix is offline
Angle grinder? Grind off the tops of the rivets on one chain link.
Or maybe a hacksaw?
BTW: Love your avatar!
Old 23-Mar-2004, 18:01   #3
Thx mate - only prob is a new chain needs to go on along with sprockets - theres 5 teeth broken off
Looks like im gonna need to find someone with a chain tool for a DID chain
Old 23-Mar-2004, 18:15   #4
Guido's Avatar
DJ,
Why do you need a DID tool? R the chains different to any other (i.e. you don't simply press the pins in place and flatten the edges off with a rivetter which I have and can post to you if required)?????
Drop me a note if my 'normal' rivetter is of some use.
Gc
Old 23-Mar-2004, 18:18   #5
Dunno just playing it safe lol - i think they are fitted as standard to dukes anyway?
I think a normal rivetter should be ok - will double check (shazaam where are you ) but would be really grateful if you can help me out - mucho beer if I can get to Cadwell!!
Old 23-Mar-2004, 18:36   #6
I fitted a did chain to my 998s
with the chain remover/fitter from hein Gericke (£50+). I suggest allways grinding the rivett tops off first anyway.
Andy
Old 23-Mar-2004, 19:04   #7
Getting the old chain off is as simple as hacksawing though the side plates. They are very soft and easy to cut.
Old 23-Mar-2004, 19:14   #8
Another idea is to loosen the chain enough so that both sprockets can be replaced, and the chain hooked back on, ride to the local bike shop and get them to replace the chain - now i know you arent supposed to run an old chain on new sprockets etc, but would it be ok for 2 or 3 miles?
Old 23-Mar-2004, 20:15   #9
Guido's Avatar
Hell yeah!!!! just put the front down B4 U go into the workshop
Can't see you can do much harm in 2-3m's
[Edited on 23-3-2004 by Guido]
Old 24-Mar-2004, 18:55   #10
Ermmmm
slight problem, the damn sprocket nut wont come off! Got someone to stand on the brake pedal while i stood on the breaker bar, it just wouldnt budge
