Old 26-Mar-2004, 15:59   #1
Starting woes
Just a quick cry for help before asking the local shop to do the necessary.
Haven't used my 748 for a few weeks and battery is a bit flat. Had to bump it and the engine started okay but then stalled. However starter motor continued to turn and then Evo alarm went off and I couldn't disarm it. Disconnected battery and alarm eventually died. Connected battery again (sparks and smoke from neg- connection); starter turning without ignition being switched on. Don't want to persevere and cause more damage.
Any ideas gratefully received.
Iain C.
Old 26-Mar-2004, 17:52   #2
Sounds like the solenoid is stuck on. It sits just in front of the battery, with two thick cables attached to it.
Give it a tap and then see if it's OK. If the bike behaves, I'd suggest you fit a new one.......just in case.
Old 26-Mar-2004, 18:57   #3
Dibble
looks like i've started a trend with these bleedin things ....
NEEEEXT ...
Old 30-Mar-2004, 11:44   #4
Thanks Nelly; new solenoid/relay did the trick.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
