Old 26-Mar-2004, 22:41   #1
rcgbob44's Avatar
Fitting C/F Airbox & JHP Filters
For those who are contemplating fitting a new airbox and the JHP undertank filters, here are a few piccy`s
B4 I started to pull things off.
Old 26-Mar-2004, 22:42   #2
rcgbob44's Avatar
here`s the old filter and injection removed.
Old 26-Mar-2004, 22:43   #3
rcgbob44's Avatar
This is the new C/F airbox with the JHP filter mounts installed.
Old 26-Mar-2004, 22:44   #4
rcgbob44's Avatar
here`s the airbox fitted with the injectors installed but without the filters.
Old 26-Mar-2004, 22:45   #5
rcgbob44's Avatar
oops forgot piccy
Old 26-Mar-2004, 22:46   #6
rcgbob44's Avatar
This is with everything done and fitted.
Old 26-Mar-2004, 22:47   #7
rcgbob44's Avatar
here`s one of the injectors - size is important!!!!
Old 26-Mar-2004, 22:48   #8
rcgbob44's Avatar
Here`s a side view with the box fitted etc.
Old 26-Mar-2004, 22:49   #9
rcgbob44's Avatar
Last but not least, the lady with her clothes back on.
Old 27-Mar-2004, 17:28   #10
Almost worth leaving your tank off to look and stare......
When i did this, i re routed the rubber fuel pipe between the two inlet tracks, putting the T piece to the right side.
I then fed the front injector pipe underneath the right hand filter, and up to the front. (Using new hose)
This cleared the underneath of the fuel tank for precious air space.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
