Old 29-Mar-2004, 20:00   #1
Billythekid Billythekid is offline
Mood: indifferent
Help Please
Ok, got probs again.
Last rode it ('95 748bp) on friday, went fine, put it away as per usual, no problem.
Tried to start it earlier and it wont fire, it just turns over. Raised tank to look inside airbox and trumpets, when cranking there is no fuel being injected in (looking in whilst opening the throttle). Also there is no spark on either cylinder.
But the fuel pump does prime the lines when you switch on the ignition, so fuel is availible at the injectors.
All the fuses are ok (checked and replaced the lot, twice!) and all the relays are working ok. All connections seem fine as well.
Ive had it recomended that the fault may possibly be the crank angle sensor (If the ECU doesnt know where the crank is how can it time the spark and injector pulse correctly!). Had a good sniff of the ECU as well and it has a faint smell of burning, though this isnt a true sign of a fault.
Has anyone else experienced problems like this that can lend a brain cell or three?
Or does anyone have a crank angle sonsor knocking around that they are willing to sell me?
I am tres pi**ed off understandibly, but also because Ive lost £145 for a trackday tomorrow as well!
Any help welcomed, thanks in advance
Joel
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:54.
