Old 02-Apr-2004, 12:02   #1
front wheel
can anyone tell me if the front wheel off 916/748 et/all fit in the forks of a 888 or SL,
Is the spindle or spacing different.
[Edited on 2-4-2004 by 888heaven]
Old 02-Apr-2004, 15:09   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
It won't fit unless you replace the bearings to accomm the smaller axle.
Rgds, Rob
Old 02-Apr-2004, 18:19   #3
front wheel
hi rob41b
thanks for replying
as there seems to be chance will the standard discs from the 888 fit or will i have to replace with 916 stuff.
ian
Old 04-Apr-2004, 23:01   #4
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
std discs off 916//88 are the same I believe..if you need a new front wheel ive got a couple of new ones in boxes here..!!
Nat
Old 05-Apr-2004, 12:44   #5
paynep's Avatar
Mood: Wet wet wet
Out of interest, does anyone know what size the 748/916 spindle is?
Old 08-Apr-2004, 15:46   #6
FiscusFish's Avatar
25mm I believe.
Darren
