Old 03-Apr-2004, 22:44   #1
custard custard is offline
Mood: yes mistress
Carbon
Hi
does anyone know the best way to repair cracked carbon fibre.?
Old 04-Apr-2004, 05:05   #2
Vlud Vlud is offline
If I'm not mistaken, there is no way to repair cracked carbon. Once all those fiber weaves become broken or separated, there is no going back. Sorry, but i have never found a way yet, only way i know, is buy a new one.
Old 04-Apr-2004, 10:29   #3
Mark853 Mark853 is offline
Mood: The medication helps!
You can patch it with normal fiberglass matting but only at the back of the carbon so as it cannot be seen. eg on the underside on a hugger. If you finish with the fine matting and then paint the repair black it can look okay from the outside.
hope this helps, saves you some money!
Old 04-Apr-2004, 11:04   #4
Mood: Avatar what Avatar
You can patch it on the back and seal the top coat but its not very successful
realy when its gone its gone mate.
Old 04-Apr-2004, 19:36   #5
neil748r neil748r is offline
Have to disagree.
I've repaired several cracked carbon parts to the point where the repair is all but invisible to the naked eye. None of the parts have "re-cracked" after the repair. Takes ages, but a bit of time is usually cheaper than a new part.
What exactly are you needing repaired?
Neil.
Old 05-Apr-2004, 19:22   #6
saj288 saj288 is offline
Try asking Simon at
www.streamlinecarbon.com
tell him I sent you!
Sally-Ann
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
