Old 07-Apr-2004, 01:08   #1
redpaul966 redpaul966 is offline
spluttering 996
can anyone help my 996 bp runs fine untill i get to 6000 rpm to7500rpm aprox ,in third gear and above can be very aggresive at times .useing 54mm silmoto 1/2 system and sil race chip .. fitted a power commander 3 and dyno and still same .had it on dyno again last week and no matter which map was used the splutter was still there at 6000rpm .ive disconected the pc3 till i can find the fault any suggestions please
Old 07-Apr-2004, 01:11   #2
neil748r neil748r is offline
Does it still splutter now you've disconnected the Power Commander?
Old 07-Apr-2004, 01:29   #3
yes neil it still splutters .ive tried everything ,changed plugs re gaped them +tensioned belts and resealed the exhaust system with assembly paste
Old 07-Apr-2004, 01:37   #4
Assuming you've checked all the obvious things, the first thing I'd do as it's real easy is take out the Sil chip and replace with the original Ducati chip. Not exactly uncommon to find that aftermarket chips have faults. Original Ducati ones are reckoned to be the most reliable. If you're running a PC3 then the chip you run is irrelevant anyway as the PC3 will be taking care of the fueling.
Does it "feel" like a fuelling problem?
[Edited on 6-4-2004 by neil748r]
Old 07-Apr-2004, 02:06   #5
if its fueling i dont think its the chip only cause the faults the same with the pc3 on or off.im hopeing someones fixed a fault with these symptomes of only happening @ certain rpm my local dealer was no help they have no ducati expert although they sell them thats why ive turned to your web site as theres nowhere ive seen as much duke nowledge ..PS excuse the deley in reply as im new to this
Old 07-Apr-2004, 03:09   #6
Fuel filter.
Old 07-Apr-2004, 08:46   #7
replaced that aswell shazaam
Old 07-Apr-2004, 08:52   #8
Mike Davis Mike Davis is offline
Mood: Shiney
Have you had the CO level checked at the take of points on the header pipes.
It should be between 4%-6% and a variation of no more than 0.5% between cylinders.
Had one in last week same problem, 1.5% between cylinders and the rear running 8% CO
Ring us on 01789 450822 for more advice.
Old 07-Apr-2004, 09:11   #9
I'm no expert but I had the same spluttering going on at about 5800-6000 rpm. If it's always at the same rev range it could be the throttle position sensor (TPS). This is basically just a potentiometer that tells the ECU how far the throttle is open, if the tracks are cracked or dirty, you would get these symptoms (although you're looking at a replacement TPS cos you can't really repair them)
Neil at Cornerspeed sorted mine out for me. Give him a call or ping him a U2U.
Old 07-Apr-2004, 19:20   #10
Co is @ 5% throttle bodys were balanced by dealer , spoke to neil @ cornerspeed gave me some advise on the TPS. it just baffles me why only @6000rpm???
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
