Old 07-Apr-2004, 19:12   #1
everton
Removing seat & rear fairing from 999R
Assuming 999R is much the same as other 999 monos can someone take me through the removal process please.
I have removed -
[list=A][*]Underseat bolts[*]Side seat bolts and plastic cowls[*]Small bolts joining both halves of rear fairing[/list=A]
Still seems to be fixed pretty good somewhere up front of seat.
What else needs removing?
[Edited on 7-4-2004 by everton]
Old 07-Apr-2004, 19:20   #2
mate you dont need to take the small bolts out on the rear fairing.
So two bolts underneath seat, twop to the side then,
gently prise the seat squab and the rear fairing together up with the rearmost of the tank.. You can then use a short length of skirting on its edge(4") to wedge the tank up in the air between the tank under side and the tops of the rear subframe.
There is then one bolt that bolts the seat squab and rear fairing to the tank a 17mm spanner. ;O)
Old 07-Apr-2004, 19:21   #3
Me inglshh is shttt!
Old 07-Apr-2004, 22:10   #4
everton
OK.............that's what this club is all about.
Put this post up at 7:15 before heading down the pub hoping for some replies on my return.
Halfway down the road, 5 mins later, gets a call on me mobile from AndyB to tell me how to take the seat unit off properly.
He even leaves a reply to ensure that I wouldn't forget when I gets home from the pub.
So, the least I can do is not forget to thank him.
Cheers mate.
Old 07-Apr-2004, 22:12   #5
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Hit repeatedly with big stick
Old 07-Apr-2004, 22:27   #6
everton
Who me or the seat unit
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:31.
