Old 07-Nov-2021, 20:22
SteveB998 SteveB998 is offline
Question 998 coolant (expansion ) tank leak issue
Hi folks , anyone had a similar problem with 998 coolant tank leaking ? It’s the one just mounted under the headstock area , I’ve previously had leak issue and replaced the tank, a couple of years ago. looks like it’s just happened again today . They seem to split at the joint on the tank as they're plastic . Quick online search seems it’s a common problem.
Just wondering if anyone found a solution or better product then stock Ducati ones ? Cheers for any thoughts / advise , SB
Old 08-Nov-2021, 09:38
I'm not sure if I'm remembering correctly, but I thought that this issue was solved on the later 998 by changing the mould for the tank and reinforcing the weak area... but maybe not!
The only other thing that I remember is some people having alu tanks made to replicate the Corse version, but I expect that these would be super hard to get hold of now.
Old 08-Nov-2021, 13:08
Cheers Antony , yes have seen online some examples of the aluminium type unit (albeit not sure anyone makes these now ) and a carbon version which are possibly in stock in Europe ! Wondered if anyone has used these ? Might be more expensive but would hopefully save replacing them . Other than not sure if you can tell the fluid level as I don’t think they have an indicator then as long as they fit shouldn’t be an issue . Appreciate any thoughts. Steve b
Old 16-Feb-2022, 19:26
Unhappy
Hi folks , for anyone interested , quick update ….. I finally fitted the new carbon coolant tank ( made by EVR from carbon4us.com) and very frustratingly (understatement ) The pipe connection nozzle on the tank failed / is faulty ! And of course leaks . So it’s on its way back to the supplier ( in Spain ) for their inspection.
I’ve refitted new Ducati standard plastic tank part and hope that one lasts …..
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:01.
