Old 18-Apr-2004, 19:47   #1
ROACHMAN ROACHMAN is offline
ROACHMAN's Avatar
TRACKDAY SEAT !
I've managed to fit my trackday fairing to the bike with not too much of a problem.
All I need to sort out is a seat pad.
The options are
1. To take the one off my road seat but if I do this I will have to cut a big square out of the trackday seat unit, will this weaken it as it is only thin fibreglass?
2. Get some foam and make a seat pad and stick it on
I think option 2 would be best but where can I get the foam from. Is there specialist foam out there for the job ?
Old 18-Apr-2004, 20:23   #2
Option 1 is probably best, but..........
you can do option 2 with a foam sheet from a Race Supply place - Dennis Trollope or maybe Demon Tweeks etc.... but these are really not comfortable.
As your seat is thin f/g, I'd go for option 1 and cut a hole in it, this is a better option IMO as the seat pad sits on top of the subframe and there is no stress on the thin f/g seat unit. With the foam pad, you're putting a lot of weight on the seat unit and it may split.
Tim
Old 18-Apr-2004, 21:44   #3
... and here I was thinking that maybe a Novice spot has opened up for the DSC jaunt at cadwell .... nevermind ...
Good luck getting your seat sorted though
TP
Old 18-Apr-2004, 21:54   #4
DSC Member AK AK is offline
AK's Avatar
If going for option 2, go to any good master saddler (for horses) they will have lots of different types of 'flocking/ neoprene/ high impact foam' types for you to choose from.
CK
Old 19-Apr-2004, 19:49   #5
ROACHMAN's Avatar
Thanks everyone,
TP 996, Im in inters at Cadwell anyway
Old 19-Apr-2004, 20:00   #6
Ahhh .. too fast for me then ROACHMAN. I'm still wet behind the ears on the whole track day thing. Yet to get out ... soon though, oh yes, it will be soon ...
Old 19-Apr-2004, 23:22   #7
wheelspin
I made a cardboard template to cut out the f/g seat unit and then took a grinder to it and made a reasonable job. You will probably need to extend the mounting points at the rear by about 16mm or so to use the seat catch thingy.
Mark
Old 20-Apr-2004, 00:38   #8
no idea of the difference in shape but did notice that MDItalia did SL seat pads...........
http://www.mdinaitalia.co.uk/page14.html
Good luck
[Edited on 19-4-2004 by Iconic944ss]
Old 21-Apr-2004, 19:42   #9
ROACHMAN's Avatar
Wheelspin,
I'll take your advice. Looked at trying to buy a second hand seat pad from a breakers but they want silly money so ill have to use the blue one off my road seat
Old 23-Apr-2004, 23:42   #10
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
James I have a grp one with a foam seat.
couldn't really get on with it that well and reverted back to my old damaged seat unit with which I swop the pad over.
You are more than welcome to the grp seat at cadwell if you haven't got it sorted by then
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:42.
