Old 18-Apr-2004, 22:45   #1
B@W B@W is offline
996 Bip brake upgrades
Just been out on my 2001 (or is it 2000?) Bip for the first time this year - jesus wept the brakes are dreadful.
I can't decide whether they've deteriorated over winter or i've just realised how bad they really are as the last bike I rode is my new ZX6 track bike with radial stoppers which are incredible.
What pads have ppl. upgraded to, or are the 4 pad Brembos a worthwhile upgrade!
Old 18-Apr-2004, 23:05   #2
The 4 pad brembos are much much better....
...might it be glazing of the brake pads if you haven't ridden her for a while?
Tim
Old 18-Apr-2004, 23:12   #3
Mike Davis Mike Davis is offline
Mood: Shiney
Cheapest option is to start with a new set of good pads i.e. Bendix MF or MRR.
And if you hav`nt changed your fluid for a while try that.
Then as Tim says try and pick up a set of four pad callipers then after that go for some cast floating discs.
You`ll get on the Kwak and then think that needs an upgrade
Old 18-Apr-2004, 23:24   #4
weagi weagi is offline
weagi's Avatar
996 brake upgrades
I've recently upgraded the brakes on my 916sps to 19mm radial master cylinder and new P4 calipers. This was a Ducati upgrade kit which also included two clip ons and new reservoir, etc. .....what a difference it has made. It's like learning to ride a new bike and last week, whilst on my 996, I could n't believe how dreadful the brakes seemed in comparision. I would wholeheartedly recommend the upgrade kit.
Old 18-Apr-2004, 23:31   #5
Mood: me in a mood? NEVER!
i have a set of 4 pad callipers sat spare on my shelf and keep think of sticking them on but to be honest its the back brake thats crap! its that bad i might just throw away the lever.
Old 19-Apr-2004, 01:52   #6
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
P4 calipers are an effective (& relativley cheap) option. The brakes on my 888 were appalling, and have just fitted brembo cast iron full floaters and a brembo radial master cylinder, and the difference is incredible..even with 'average' pads.
Everyone should have a brembo radial MC !- there just brilliant and look trick (see pic!)
I have the 96823402B
ducati performance SBK radial upgrade kits here..consisting of a 19x20 radial master cylinder, braided hose kit, and the pressure switch to operate the brake light. List is £456.12...if you want one ill do it for £250...U2U if interested
Nat
Old 19-Apr-2004, 10:35   #7
Nattyboy's Avatar
Weeksy - get the proper ducati item - part number 96818500b...£28 which is specifically recommended for the brembo MC. There are some cheaper versions (around £20) but they are not as well made..and for the sake of £8 id always go genuine.
Nat
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:42.
