Old 08-Jun-2003, 21:15   #1
Sticky Sticky is offline
996 rechip
Hi new to DSC.
Querie. I have a 996 with 45mm remus grand prix carbon cans. It still has the factory chip in the ecu. Some people advise that I should rechip with the ducati chip for £35 some say that it doesn't need rechipping. What do I do?
What will rechipping do and will I notice it on the road. Can I do it myself as I know where it goes and what to do. Ducati want £100 to fit it. What else will they do as fitting the chip is a 5 minute job and the have quoted me 2 hours?? Any advice greatly received.
Sticky
Old 08-Jun-2003, 22:52   #2
pj748r pj748r is offline
Mood: FIVE!!!!Guess We'll Keep It
best thing to do is go on the old message board and have a look at the old threads about chips.i have fitted 50mm blueflames to my 748r and it is a bit fluffy low down 3500-4000rpm,am having ducati performance chip fitted at moment(in for service+newcamshaft/rockers @6k service!!!).will see what difference that makes as blueflame supplied me with a casoli moto chip which said 748sps on it but was assured by casoli moto that it would do the 748r,it ran like a bag of sh$7e,fitted standard chip it ran a lot better,so will let you know after i get bike back . .JHP chips or FIM seem to get good reviews as well.ps buy the chip yourself and fit it,just remember to earth yourself before you remove the chip.hope this helps
Old 09-Jun-2003, 02:45   #3
Slip-ons are for better sound and aren't really a big performance enhancement. At the most, you'll get a 2-4 peak horsepower increase (@ 6,000 - 9,000 rpm respectively for Termignoni's.) EPROM chip makers usually are just bringing the mixture back from the slightly lean condition that Ducati uses to meet emission targets.
Generally you can put the exhaust cans on and have your dealer re-adjust the CO level to compensate for (minor, if any) increased airflow. There's a CO trimmer screw adjustment on the ECU that provides for limited fuel mix increases. The trimmer affects fuel delivery over the entire rpm range, but with a lesser effect at higher rpm. Go easy, a half-turn on the screw is all that's usually needed and too much fuel affects throttle response and idle adversely.
Always a good measure is check the color of the inside of the tailpipe after a few hundred miles. It should be light to medium grey. I can't tell you how many chipped Ducati's I've seen running around with blackened pipes just pouring gas money out the back. BTW, half or full exhaust systems DO need revised EPROM's since they do significantly increase airflow and do require increased fuel to compensate and prevent severe lean conditions that damage engines.
That said, I bought a Ducati Performance chip having a generic slip-on fuel map. The improvement in low end throttle response and horsepower at the top end is noticeable. The tailpipe color is medium grey now and the gas mileage is down roughly 10 - 15%. The rev limiter rpm is also raised. However, the mixture difference between cylinders is now more noticeable. One tailpipe is less grey indicating a leaner mixture. This bears out the major selling point for FIM chips is that they have different fuel map adjustments for each cylinder, the other brands do not. But, in order to take full advantage of FIM chips you need to make some dyno runs with an experienced tuner.
However, dyno tuning usually involves setting the fuel mixture for maximum horsepower at high rpm. Best power is usually realized when full-throttle CO is in the 4-6% range. But be careful, this may also result in an overly rich mixture at midrange rpm where you do most of your riding. Your choice.
Finally, all EPROM chips sold for aftermarket exhausts are not the same. They usually provide enrichment (over the stock chip) across the RPM range but some bikes just - don't - like certain chips; Ferracci chips, for example, tend to be mentioned most often regarding overly-rich mixtures causing stumbling in the lower rpm range.
Old 09-Jun-2003, 10:36   #4
DJ Tera DJ Tera is offline
Theres a guy on ebay doing Power commanders for all bikes, only $255! They let you offset the mixture for the rear cylinder two, doesnt have two specific maps but it shouldnt be a problem. I've ordered one for my 998, just waiting for it to arrive now!
Old 09-Jun-2003, 10:39   #5
Felix Felix is offline
Not to alarm anyone thinking of using a Power Commander on their 998, but I've read on a US BBS that more than one person reportedly had fried the injectors. No further details were given, but beware.
Old 09-Jun-2003, 10:40   #6
Could you post the link please mate
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:59.
