Old 22-Apr-2004, 21:31   #1
Jasper Jasper is offline
Jasper's Avatar
PC HELP-PLEASE!!
PC's crashed after a power cut,told me a file is corrupt or missing.How do i re-install the file from the disac if windows won't boot|?OR..How do i use syatem recovery.
I am using xp pro.A phone number would be nice.Remember...it's good to talk!!
Old 22-Apr-2004, 22:02   #2
fodder fodder is offline
Mood: sleepy
How far does XP get before the errors appear?
On switching on keep tapping the f8 key, it should then give you the option to start windows in "safe" mode. Try that.
If you do get windows to boot up the easiest option is to run a system restore which can be found in accesories/system tools on the program menu.
[Edited on 22-4-2004 by fodder]
Old 22-Apr-2004, 23:06   #3
Jasper's Avatar
Don't get to windows.get system 32/hal/.dll missing or corrupt,please re-install file-HOW!!!?
Old 23-Apr-2004, 06:52   #4
Put your original XP CD into the cd drive then reset your PC.
XP discs are "bootable" so it should startup off that rather than your corrupt hard-drive and be able to restore the bits that are missing.
Don't forget that you'll need to run Windows Update again once you've done this (Internet Explorer -> Tools -> Windows Update)
Old 23-Apr-2004, 09:43   #5
Jasper's Avatar
Cheers,will try again!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:37.
