Old 24-Apr-2004, 20:48   #1
Wot about tyre pressures?
Wot you running yer 999 on pressure wise? It says in the book 2.1 +2.2 bar front and rear respectively.
Whats that in the real world of psi?
And, how do you find the right pressure to suit your riding style?
Old 24-Apr-2004, 20:49   #2
oh and do you think my 999r rims need more pressure to protect them as they are the lightweight forged jobbies?
Old 24-Apr-2004, 20:52   #3
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
30/32 if my calculations are correct and it works for me, road and track, don't know if body weight makes a difference, as I am a bit of a FB
Old 24-Apr-2004, 21:07   #4
Are you on a 190 rear FB ;o) cos tween u and me , im an FB aswell...
Old 24-Apr-2004, 21:09   #5
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
to get psi
2.1 x 14.5 = 30.45 lb per sq.in
2.2 x 14.5 = 31.9 lb per sq.in
[Edited on 24-4-2004 by Nigel C]
Old 24-Apr-2004, 21:22   #6
190 Andy.
Near enough then Nigel, didn't even use a calculator
Old 24-Apr-2004, 21:30   #7
Its just my rear was nearly 40psi as delivered!! and my front 36. Now my guage is calibrated so i believe its correct!!!
I thought this was high so i dropped the pressures to 34psi, and now it seems a bit loose! sort of squirmy.. understand wot i mean?
Old 24-Apr-2004, 21:45   #8
Front 30psi
Rear 32psi (180)
Feels ok to me.Just had some Dunlops fitted and the front end seems a little more harsh compared to the OE Mich's.Stiffer sidewalls maybe?
Old 25-Apr-2004, 12:23   #9
hk999 hk999 is offline
i am running on 34/36 at the moment (on OE Pilot Sport)...have to say its a bit harsh and nervous...
Old 26-Apr-2004, 12:45   #10
bazzer sps bazzer sps is offline
I was just checking out the tyre range on the Bridgeston web site and they quote 36psi & 42psi or 2.5bar / 2.9bar for the 999 on 010's.
So how do you decide on the right pressures with the bike mfg quoting 1 set of pressures and the tyre mfg another especially if you take into account insurance type issues.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:22.
