Old 26-Apr-2004, 20:38   #1
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Graunching Clutch
Has anyone come up with a solution for the graunching clutch noise when setting off in first gear. I have been taking out the plates and putting them back in different order which cures the problem for a short while.
Ideas anyone?
Old 27-Apr-2004, 09:52   #2
In my experience that usually means that the clutch is on its last legs.
Old 08-May-2004, 10:18   #3
chrisw's Avatar
clutch
After a bit of searching on other threads found that by cleaning the glazing off the metal plates with a scotchbrite rotoary disc in a drill, problem solved.
The actual clutch friction plates are in good order, no wear on the friction material or tangs.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:22.
