Old 09-Jun-2003, 10:39   #1
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
On the subject of huggers
I have got a DP hugger, and somewhere in the last week or so, i have lost the "tunnel" piece through which the rear brake cable is routed - the result is that the cable has been rubbing againts the tyre, and both have worn ,somewhat.
Can i get a new one, or does anyone have a remidy ..... the current zip ties look a bit naff!!
Old 09-Jun-2003, 10:42   #2
Felix Felix is offline
It's not a cable you know, it's a hydraulic line and if it's significantly worn I'd replace or you risk not only a complete failure of the rear brake but brake fluid all over your back tyre. Not fun!
Old 09-Jun-2003, 11:55   #3
Sorry, wrong glossary. Yes, I know it is a hydraulic line.
The out plastic case has worn thru to the braiding, but the inner braided area is unmarked/ un worn ....
Replace, or leave?
Old 09-Jun-2003, 12:50   #4
When in doubt, replace...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:59.
