Old 29-Apr-2004, 16:47   #1
m1keyp m1keyp is offline
SIDE STAND BYPASS
Hi
Can anyone advise of a downside to fitted the sidestand bypass wiring to the Bl**dy annoying cut out.
Any feedback is welcome.
Thanks Mike
Old 29-Apr-2004, 17:07   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I've got the Cornerspeed version fitted and I cannot think of a downside at all.
Unless you include having to buy one in the first place... should have been standard IMHO
Old 30-Apr-2004, 00:30   #3
moto748 moto748 is offline
I converted mine back to the old "flip-up" design. Once you're used to it, I don't have a problem with it.
Sidestand switches are just an electrical problem waiting to happen, sited in the worst place for getting muck and rain in them. And they're not just a problem on Ducatis, either. Just read any web bike forum.
[Edited on 29-4-2004 by moto748]
Old 30-Apr-2004, 00:39   #4
pj748r pj748r is offline
Mood: FIVE!!!!Guess We'll Keep It
bought a sidestand bypass kit from nelly at cornerspeed about october last year,fitted brill and uses oe style fitments,so no probs,have given it and all electrical connections a liberal coating of wd40 every time i clean the bike but then i did that with all my jap shi?e anyhow,best £25 i ever spent.nothing worse than sitting on your bike waiting for it to warm up!!
Old 30-Apr-2004, 11:33   #5
Ray Ray is offline
Ray's Avatar
I wired up one myself, cost only pence but it took me a while, If I had charged myself for the time it probably isn't worth it!!!
The proper kit from Nelly looks part of the bike and is easy to fit.
The info on how to make one yerself is somewhere on the board.
Ray
Old 30-Apr-2004, 12:07   #6
Nelly\'s your man....
.....top piece of kit.
You can make one yourself, but I'm not sure that this would incorporate the "engine cut-out if you engage gear with the sidestand down thingy"
Tim
Old 30-Apr-2004, 13:34   #7
Ray Ray is offline
Ray's Avatar
Rtlr,
You can go two ways with the DIY job.
One is just removing the switch and putting a loop/jumper between two connections in the bare plug left. This means that you can run the bike with the sidestand down but set off with the side stand down unless you make further mods.
Two involves running a wire from the neutral switch withyan electrical thingy in it to a the sidestand switch plug, this allows the engine to run with the sidestand down but as soon as you select a gear with eh stand down i.e. the neutral light goes out the engine cuts.
DIY method one is quick but could involve pain if you set off with the side stand down.
DIY method two takes a while, well it did for me, but is basically what all the proper kits do.
Unless you are reasonably confident with electrickery buy the proper kit!!
Ray.
[Edited on 30-4-2004 by Ray]
Old 30-Apr-2004, 13:49   #8
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
I got my kit from Bike Gizmos. (they have a wesite)
They are in Australia but delivery time was less than a week from placing my order.
This one uses Ducati style weatherproof connectors and only cost me £21 including postage from Oz
