Old 04-May-2004, 18:30   #1
JACKO748S JACKO748S is offline
JACKO748S's Avatar
Sorry - wrong section but...........
I need max exposure for some quick responses.
Just had a call from the garage where my 01 748S is being serviced. It needs a new Chain and Sprocket set.
My question is, would I benefit from lowering the gearing by upping the teeth on the rear?
Has anyone done this out there? I have done a search but cannot find a definitive answer for the 748S.
They have to order the set in and I want to phone them first thing tomorrow to let them know if I want to change from the standard set-up. Hopefully avoid messing them about.
The thought only came to me after the shop had shut for the day.
Any quick advice much appreciated.
Churz - Jacko.
Old 04-May-2004, 18:38   #2
ziggi ziggi is offline
ziggi's Avatar
Loadsa people done it. Don't know about best combination of front & rear sprockets but long and short of it is -
1. choose whether to change the front sprocket (down on teeth) or rear sprocket (up on teeth) or both
2. choose whether to get a quick change sprocket carrier for rear or stay with fixed carrier & sprocket.
I'm sure the 748 boyz /gurlz will help you on sprocket options.
Old 04-May-2004, 18:50   #3
Go for it....I love having more accleration over ultimate top-end - which having said that how often (and where!) can you use it these days anyway.
Old 04-May-2004, 18:57   #4
DJ Tera DJ Tera is offline
wot he said - no point having 165mph top end if it takes a couple of miles to get there!
Knock it down 1 on the front (if its a 15 - DONT goto a 13 as it stresses the chain too much) or put 3 or 4 on the rear (this will require extra chain links, but they are putting a new chain on so no bother )
Old 04-May-2004, 19:07   #5
A stock 748s has a 14-tooth front sprocket and a 38-tooth rear sprocket, with a 94-link 520 chain.
A popular choice, that I recommend, for 7XX models is a 14-tooth front with a 41-tooth rear that will require a 96-link chain. The set-up will raise your ride height a little (4mm) which will improve the bike's cornering.
Old 04-May-2004, 22:19   #6
JACKO748S's Avatar
Cheers guys! Once again, quality advice comes forth.
I always understood the principles behind lowering the gearing, just wasn't sure whether it was that beneficial to actually do it.
Thanks again.
Jacko.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:36.
