Old 05-May-2004, 19:00   #1
Ned Ned is offline
\"Cons\"
Has anyone worked out what the CONS reading is meant to tell me? Bottom RH corner of LCD display.
I read the manual, and they don't say anything beyond "Consumption Indicator)...
I tried looking at it as I'm going along, and I think it's trying to say "You've got 20 miles left in the tank", but it seems so variable as to be totally useless... I'm certainly not going to trust it, but I'd be interested to know all the same
Ned
Old 05-May-2004, 19:03   #2
chris999 chris999 is offline
Mood: red and proud !!!!
it is your fuel consumption at the time..
but if it is anything like mine it will start indicating all sorts...
Old 05-May-2004, 19:39   #3
webbyc webbyc is offline
webbyc's Avatar
It's the instantanous fuel consumption and automatically comes on when the low fuel light comes on. It varies ebcause it is workingout what the fuel consumption is at any time. Similar in a way to the guage on the speedo on a BMW car.
Old 06-May-2004, 07:13   #4
dickieducati's Avatar
ita about as useful as a chocolate teapot.
Old 06-May-2004, 08:09   #5
Mood: going for a ride...
It works in conjunction with the fuel light instead of a reserve tap on your tank , once the low fuel light comes on the Battery / Air temp / Cons display will only show Cons , or mileage left in the tank at your current speed / throttle position.
You will notice that the figure changes as you go slower or faster indicating the different tank range left at your current speed.
Best bet is fill up every 100 miles (the fuel light came on at around 90 miles on my 999S) , or buy a 749R and get a proper size tank
Old 06-May-2004, 11:12   #6
Ned Ned is offline
Thanks YFE. That makes sense to me.
Ned
Old 06-May-2004, 19:11   #7
Loz Loz is offline
Loz's Avatar
Fuel Tank
Speaking of decent range and fuel tanks, does Ducati do a larger size tank for the 999S in standard trim rather than carbon fibre? There's no mention of such in my DP catalogue.
Not that I have anything against carbon, of course!
Old 07-May-2004, 07:48   #8
I'm sure you could buy a 749R tank and fit that to a 999S , I dread to think what the price would be though , probably cheaper than carbon though
Old 07-May-2004, 13:08   #9
guest1 guest1 is offline
So when the fuel light comes on, does Cons show current consumption or estimated miles left in tank?
Old 07-May-2004, 14:52   #10
Tank range , as stated above , it's not rocket science
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:58.
