Old 09-Jun-2003, 22:29   #1
CJ748 CJ748 is offline
Mood: Summertime:~]
Ultimap chips
Has anyone else had problems with these chips?
I bought one last year fitted/dyno'd. I was told it was right but it never quite seemed perfect !
I explained running problems to Tony at 2-4-Italia and he did a bit of work on it only to discover the chip was naff !!!!
Has anyone else had this or had any probs with getting a refund?
CJ
Old 09-Jun-2003, 22:35   #2
scoot scoot is offline
Mood: what mood
bought mine from 2/4 italia and let a proper mechanic set it up as tony could not get it right after the thrid attempt went straight to jhp no problem sorted it first time.
i will not say any more or it will be censored!!!
Old 09-Jun-2003, 22:43   #3
Mood: Summertime:~]
Chips
Scoot,
Thanks for reply, it seems some of the various "specialists" have varying degrees of success !!!!
What BHP did you get at JHP compared to 2-4 ?
CJ
Old 10-Jun-2003, 09:46   #4
Mood: what mood
the bhp went from 110 to 119 but the way it changed and how smooth it was and it does not drop of untill 11000 rpm
torque up as well but only by 5/6 ftlb making about 65ftlb at 8500 rpm.
this was after it was dynoed just shows you what a diffrence setting it up right will give you
[Edited on 10-6-2003 by scoot]
Old 10-Jun-2003, 09:48   #5
alb916 alb916 is offline
My 916 came with 50mm cans and a unfitted FIM chip (ducati one fitted)
On trying to find out more info about FIM, I emailed ULTIMAP/FIM (Australia) to be told I had an earlier version of the 916 chip and to take it to my nearest FIM supplier and they would replace it free with the latest type.
Had it swaped over without any complaint(Pro-twins), plugged it in and it was great, next step is to have it tuned.
End result I was impressed by FIM customer service and the chip.
Old 10-Jun-2003, 10:26   #6
Mood: Summertime:~]
Thanks for valuable info guys.
I'll get onto Pro twins asap. Hopefully they can give me a rough BHP/Torque figure as now although power is very smooth and all the way to 11000 it is only 90 at the rear on a 748 BP !?
CJ
Old 10-Jun-2003, 14:56   #7
rcgbob44's Avatar
Chips
I swear by Protwins, Ugly bunch though!
Old 10-Jun-2003, 16:24   #8
90 at the back wheel, won't be far off. Take a look here UM091 graph on the FIM website .
It's making about 93 ish.
It's the delivery and the extra rpm you'll notice most.
I've got one in mine and it's great. It's easier to set up IMO to. You notice the twin mapping on the CO meter straight away compared to the conventional eproms.
Old 10-Jun-2003, 18:49   #9
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Nigel Booker's Avatar
I've had two ultimap chips in the 996 the first was a straight swap for the DP chip a UM196 this knocked the 6bhp off the top end but made the engine run smoother. After contacting ProVtwins it was discovered that the wrong chip had been supplied and they swapped it for a UM222, single injector chip. Once this was fitted the bike pulls harder from any revs runs smoother with no coughing and spluttering were the second injector would normally cut in and it now revs clean to 11k and has 118bhp at the rw.
I would definately recommend ProVtwins for FIM chips they seem to know what works and what doesn't.
Old 10-Jun-2003, 21:26   #10
den den is offline
Is there anybody up in sunny Jockland that can be recommended to supply and set up ultimap chips ??
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:41.
