Old 08-May-2004, 12:00   #1
logyk logyk is offline
logyk's Avatar
Mood: Relaxed - don't worry about things you can't change
Recall - Oil Cooler
Beware all riders of 999's.
Just received a recall on my bike. Apparently there is a possibility of the oil cooler failing and dumping all the oil on the rear tyre..........nice !!!!!
Suggest you all get yours checked ASAP....would hate to hear of someone going down as a result of this.
Old 10-May-2004, 15:05   #2
guest1 guest1 is offline
Happened to mine within first 600 miles.
Came out to start it, left it warming to put jacket on and oil was spurting into belly pan and onto floor.
As I understand it, the original is Jap and it is replaced with identical KTM unit.
On my original, the leak was from the top left just near to the top most hose connection (when viewed from within fairing).
I now leave the bike on tickover for a minute and checking for oil drips is the last thing before setting off.
Old 10-May-2004, 15:58   #3
Loz Loz is offline
Loz's Avatar
Logyk & Alan E
Thanks for the heads-up here. I've had no problem so far, but I phoned my garage anyway. They inform me that my 999S will need this work. When I think of what might have happened ...
Thanks again!
Old 10-May-2004, 20:58   #4
bazzer sps bazzer sps is offline
Having phoned Ducati Uk the 999 chassis No's affected are
ZZMH400AA2B000001 - 007801
There were 2 types used a KTM and a TOYO if its the KTM then its probably needs replacing.The TOYO is apparently ok.As i'm going to WDW next week i was getting anxious but thank fully my 999 fitted with the TOYO
Old 10-May-2004, 23:33   #5
jk2 jk2 is offline
jk2's Avatar
Infected oil cooler!!
How do you tell the differrence between KTM and Toyo oil coolers?
Old 10-May-2004, 23:54   #6
everton
Got my recall letter on Saturday...............
...............my frame number being near the end of the batch.
Done about 1600 miles now with no problems but will still get it checked out pronto.
Old 11-May-2004, 15:13   #7
hate to say "I told you so" but...
http://217.199.188.40/xmb/viewthread...=5688#pid45365
Old 11-May-2004, 19:35   #8
Yep,got my recall notice today.
Is there anything stamped or printed on the oil cooler to determine the manufacturer?
Old 11-May-2004, 21:28   #9
If you take off the right hand side body panel or if if your lucky you may be able to see it without removing the panel.The difference is the TOYO oil cooler has a sticker on the top with the words TOYO in white lettering,the KTM apparently has no ID.
I hope this helps.
Old 11-May-2004, 22:08   #10
bugger... mine chassis no is just inside the recall, will check to see whats fitted.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:31.
