Old 11-May-2004, 12:35   #1
Harv748 Harv748 is offline
Harv748's Avatar
Brembo radial MC
So gonna buy the above...but what bore/ratio do I need.
748 with P4 calipers? I've read that either on offer will do...but which is better, which gives best performance?
Old 11-May-2004, 13:07   #2
All the variants are 19mm bore. It's the leverage ratio that changes.
x16, x18 and x20 are available.
x20 is the most common.
x16 will give the most feel, x18 will decrease the feel, but be easier to pull and x20 will give the least feel but will be the lightest pull.
Prices do differ depending upon ratio to, but not by much.
[Edited on 11-5-2004 by nelly]
Old 11-May-2004, 18:21   #3
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Ive got x18 ... have used the x20 and prefer the 18..
Nat
Old 11-May-2004, 20:27   #4
DJ Tera DJ Tera is offline
IMO the brembos are overpriced for what they are - on the continent you get CNC machined cylinders with flip up levers (saves the lever if the bike goes down) for about 200 euros, not only are they TUV approved but they also have a brake switch fitted.
For just a bit more than the cost of a Brembo you can have matching clutch and brake radial cylinders!
BTW whats with the gay new smilies on the board (i think the lol and :d ones are the wrong way round too)
[Edited on 11-5-2004 by DJ Tera]
Old 11-May-2004, 20:47   #5
Harv748's Avatar
Natt...why did you prefer the 18?
DJ...got any links/details of the units you mention?
Old 11-May-2004, 21:30   #6
Harv, here ya go mate
http://www.redracingparts.it
Old 14-May-2004, 23:01   #7
DSC Member Karl Karl is offline
Karl's Avatar
Harv
In case you still haven`t got a definative answer, found this in the Brembo Cat:
Lever Ratio................................. Recomended Fitment
20mm..........................................OE twin caliper. Popular for road
18mm..........................................Raci ng twin caliper
16mm..........................................125c c+ / Supermoto single caliper
"18 is recomended for use with Brembo racing calipers and 20 for all other makes of caliper" hope it helps
Old 15-May-2004, 02:35   #8
Harv748's Avatar
Cheers Karl...yep...I'm thinking 18mm, combination of both feel and strength.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
