Old 13-May-2004, 16:02   #1
Mr_S Mr_S is offline
Refitting Standard Cans
I've currently got a set of termi cans fitted, but in a couple of weeks I've got an Edge 44 assesment with on of the local bike plod, sooo, thinking sensibly I want to refit the standard cans, and not mark myself out as a hooligan
How easy is it? I'm reasonably technically minded, is it a challenge or just more of a big jigsaw that's a Bu&&er to assemble?
Jason
Old 13-May-2004, 17:04   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
It's not too difficult at all jason.
Swapped mine recently for MOT time. A couple of points to think about though....
Getting the holes to line up was a bit of a puzzle - succeeded after a lot of tugging on the pipes. I'm assuming that where the original pipes were sitting in the attick for ages that the temp changes had slightly mis-shaped them, but it wasn't too much trouble.
Another thing I found out was that the silencer clamps from the Termi's don't fit the standard cans so not having the original clamps, I had to fashion some out of some old ally plate I had lying about. This was a total bodgit job so I'd recommend you get some original clamps if you've not already got some.
And finally...... watch out for them springs - they bite!
Old 13-May-2004, 19:05   #3
Jason - check with them first. I spoke to a guy about this corse at the end of last year and he seemed ok with race cans...now number plates, different story...otherwise, as Nick says, should't be too much of a problem. Only done it once but took less than an hour - springs are the fiddly bit.
Old 14-May-2004, 00:35   #4
A local expert I can call on then when it all goes wrong...
I'll call them and check and may give it a miss then, MOT's next spring and trackdays would be the only other reason to swap them, and I've not booked any yet
Number plates fine, got sick of being pulled for a slightly smaller one on the R1.
[Edited on 13-5-2004 by Mr_S]
Old 14-May-2004, 00:41   #5
NBs996's Avatar
I too am pretty local Jason.
It won't go wrong but throw me a u2u if you need some assistance mate, I'll bring my spanner and spring puller!
[Edited on 13-5-2004 by NBs996]
Old 14-May-2004, 01:48   #6
and I'll supply the endless inane chatter about nothing...
Old 14-May-2004, 13:44   #7
Numberplate shouldn't make any difference as it's not part of the bike MOT, but it is for cars.
Old 15-May-2004, 13:15   #8
Edge44 is police initiative run by bike cops...depends on size of plate I would guess
