Old 26-May-2004, 10:15
lane748's Avatar
lane748 lane748 is offline
Mood: mmmm....yellow!
Brembo caliper bolts
Where can i purchase some replacment bolts that hold the two halves of the caliper together? I fancy Stainless steel as the existing ones have gone rusty & look unsightly. However, I dont want to buy a bucket full of assorted bolts & nuts just to get 8 !!
What is the thread size & length of these bolts?
Old 26-May-2004, 10:18
M8 x 40mm
Old 26-May-2004, 11:30
Are you seriously planning to replace the bolts holding the caliper halves together or are you talking about the bolts that hold the calipers to the forks?
Old 26-May-2004, 18:23
uncle porry's Avatar
uncle porry uncle porry is offline
caliper pinch bolts, i think they`re called....
Old 26-May-2004, 19:39
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
I've done the actual caliper bolts on my last two bikes...no problemo!
Old 26-May-2004, 22:21
I've done the bolts that hold the calipers to the forks as well but i wouldnt touch the bolts that hold the caliper halves together. Way too much risk of the caliper flexing when you hit the brakes if you havent got it exactly right when you tighten them up in my opinion.
Old 26-May-2004, 22:22
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
I did it alsoon my old 748. I could not get the correct bolt anywher and ended up buying a set of Ti bolts for front and rear caliper. £60.00 if I remember right
If you do it Andy, only change one bolt at a time.
[Edited on 26-5-2004 by Jon]
Old 03-Jun-2004, 19:08
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
Youve got me rattled now !!! I was going to change the bolts that hold the caliper halves together on those brembo billets ive just bought (there a bit tatty as you can see)..so general rule is just change one at a time and you should be fine then?? Assume no torque settings available ??
Nat
  #9
Old 04-Jun-2004, 01:24
rcgbob44's Avatar
nat
i`ve changed these b4 for s/s and had no problems at all, just do one at a time.
bob
  #10
Old 04-Jun-2004, 12:58
neil748r neil748r is offline
The only issue with changing to stainless bolts is that stainless does not have the tensile strength of the original bolts. Best option is to change to titanium.
For advice on torque settings etc give James Walters at Brembo UK a call: 01908 220777.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:57.
