Old 27-May-2004, 15:54   #1
Jelley Jelley is offline
Carbon, Carbon, Carbon
Hello chaps,
Is ther any particular place you get your carbon bits from??
there seems to be alot on Ebay, but i'm worried about the qaulity of the stuff?? any shops you recommend?
I want to kick of with a rear hugger, have you all got the one that has the chain guard on it aswell??
Jelley
Old 27-May-2004, 16:04   #2
moto748 moto748 is offline
The genuine Ducati huggers (short and long) are going for £70 and £100 + postage on Ebay at the mo.
Old 27-May-2004, 16:04   #3
Dibble
Try here .....
http://www.btinternet.com/~ripsnortingtwin/
Mike is an ex member and Ducati nut, tell him I sent you over, loads of people here have his carbon including Jasper, Jon & myself amongst others ...
Pietro
Old 27-May-2004, 16:05   #4
Jasper Jasper is offline
Jasper's Avatar
Rip's stuff is superb.Service is good too.
Old 29-May-2004, 23:34   #5
rcgbob44's Avatar
I have a lot of D.P stuff on my duke and personally i think the finish is rubbish!
Old 30-May-2004, 21:23   #6
Here's a thing about huggers. On the 748 (can't comment on the 9**), if you run the stock gearing, the hugger runs *very* close to the tyre. This can result in the tyre wearing a hole in the hugger. Look around at Dukes you see, and this not uncommon. Running a bigger rear sprocket, and a slightly longer chain, moves the tyre well clear of the hugger.
Someone will be along shortly to tell you that this changes the geometry of the bike, and the ride height should be re-set, no doubt...
But it's true about the hugger. Just thought it was worth mentioning.
Old 30-May-2004, 21:37   #7
mike mike is offline
mike's Avatar
When i fitted the DP hugger to my 748 it rubbed the tyre resulting in a hole..i repaired this and now the same hugger on my 996 is fine with plenty of clearance...
Old 30-May-2004, 22:06   #8
Plenty of room with my hugger on my 996.
Old 30-May-2004, 23:01   #9
DJ Tera DJ Tera is offline
It depends on what tyre you run - I ran 190/50 bt012 and a 190/55 rennsport with no troubles, stuck a 180/55 D208GPa and it wore hole within 200miles
Old 30-May-2004, 23:04   #10
955matt 955matt is offline
955matt's Avatar
Mood: Allways Good if up right!!!
Hi fitted a hugger with chain guard on my 916 no probs here .Bought mine out of mcn its a DP product looks great.
Hope this helps Matt
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:58.
