DesmoDue Series Information
Documentation & info to help prospective & current DesmoDue Racers
Old 27-Nov-2008, 14:19   #1
Dominic Clegg's Avatar
Help for DesmoDue Newbies
As sure a few of you are aware it can be difficult to know where to go to find up grades and just general race kit for the desmodue race bikes.
I am starting this thread to pool together information that we have with the intention of creating a stick post (or adding to my stick want to be a dd racer?) with aproval from MT if this is with in the advertising rules
with list of companys and where to find help when building a race bike and finding spares.
Example
http://www.ricambiweiss.de/ For race fairings
http://www.hcracetech.co.uk/ Also race fairings - Matt T sponser
http://stores.ebay.co.uk/Race-Supplies-Direct For rear sets and clip ons (what size do you need?)
Race exhaust system by MHP
http://www.racinglines.co.uk/ For race suspension work
That type of Idea
Old 28-Nov-2008, 08:55   #2
harriebird harriebird is offline
harriebird's Avatar
it doesnt relate to parts etc but i wrote a "how i got started" for another forum. it descends off topic a bit but here it is if anyone needs it.
http://www.essexbikers.co.uk/forum/s...ead.php?t=8272
Old 30-Nov-2008, 19:51   #3
faith-healer faith-healer is offline
I would also highly recommend Maxton Suspension not just for new units but for refurb'ing forks and rear shocks.
New springs to suit rider/bike damping mods, full services and bushes etc..
First class @ http://www.maxton.netspinners.co.uk
They are always very busy so email....don't depend on the phone calls being return quickly
Old 15-Dec-2008, 22:13   #4
Aquila Powder Coatings Ltd
Unit 3, Brook Forge,Hightown Rd, Cleckheaton, West Yorkshire BD19 5JS
Tel: 01274 855008
Old 15-Dec-2008, 23:46   #5
Dom,
Rather than have many individual posts on one thread, can they all be put into one list???
A few to add to that list would be.
http://www.jacexhausts.co.uk/index.html
They did the exhaust system on Matt's bike.
http://www.ultimate-finish.co.uk/
Did Matt's frame and a frame for Skid's.
http://www.carrotcycles.co.uk/
Converted 748/916 throttle and cable to be used on a 583.
Old 01-Feb-2009, 23:36   #6
Some Info Kindly supplied By Skidlids (Kev Ellis):
Some info for those starting out in Desmo Due
I'll try and add to this over time
Class B 583cc bikes
Gearing
Renthal Rear Sprocket part No. 236 -520 -No. of Teeth
eg 236-520-43
Very early engines with 2.28 to 1 primary ratio
Rear sprockets 39 - 38 - 37
Front 15
Chain either 96 or 98 link
Most common 583 engine (most SS models from 1995 on)
with the 2 to 1 primary ratio
rear Sprockets 43 - 42 - 41
Front 15
Chain 98 link
Last of the 583 engines as found in late monsters
Clutch slave on the left with a 1.85 to 1 primary ratio
Not fully upto speed on this one yet but would be looking at
Rears 48 - 47 - 46
Fronts 15 -14
Chain 100 links
Fork springs
Early Marzocchis (40mm caliper mount)
I have used Ohlins springs
08805-01
VTR1000 Firestorm = 0.85kg/mm
alternative for the lighter rider
80029
8634-80
CBR600FV/FW = 0.8kg/mm
In the later Marzocchi forks (65mm caliper mount)
I have used Ohlins springs for a 748/916
08627-90
Air Gap 110mm to 120mm (the nearer to 110mm the better)
When adjusting the air gap 6.25cc of Oil = 5mm of Air Gap
Fork leg tie wrap to be approx 5 mm to 10 mm off the bottom of the fork leg
(thanks to Chris P for the air gap & volume info)
Speedo drive replacement spacer
Early Marzocchis with 20mm spindle, made mine with a step in it
ID = 20mm clearance
OD at fork end = 35mm
OD at wheel bearing end = 33mm
Width = 35mm
Later forks with 25mm spindle (will try and add this info later)
ID = 25mm Clearance
OD at fork end = 32mm minimum, mine is 35mm
OD at wheel end = 32mm
Width = 30mm
Cambelts
Early 583s with Square tooth belt
part No. 066029090
Last of the 583s with round tooth belt
part No. 73710051A
Gaskets
583
Exhaust Gasket - 037084005
Base Gasket - 78610471A
Rocker Cover Gasket - 78810322A
Some more info from Chris P.
Originally Posted by Chris P.
To add to Skids info on these forks.
(do not forget to use a smaller spacer above the springs to give you the correct static sag, as the 748 springs are longer than the standard Showa's.)
Will give a more detailed suspension settings over the weekend ( if thats ok with skids )
More....................
Originally Posted by Imola Duke
Hi
If i changed my standard spring on my 750ssie showa shock
to a single rate spring what approx weight spring would you
advise me to use and what spring manufacture ?
If i did this would the damping & rebound be ok ?
Thanks in advance for help
Originally Posted by Skidlids
Steve the damping should be OK as it has quite a wide range to deal with being built for a road bike that may or may not require the carrying of a passenger.
Spring rate will depend partly on your weight with riding gearing on.
I go to Race Parts for my springs as I get a good deal but have to wait for them to order in as they only stock balanced pairs for the car racers. Otherwise try K-tech or JHP
Thanks Kev
I'll get me leathers on etc and weigh myself pre Xmas
Btw... I have made a simple but affective ride height adjuster to
use with the ie shock. (I'll post up a pic when it's fitted)
I did plan on buying a new shock but this credit C has hit work hard
so i'll make best use of what i have for next year!
Will the shock supplier need to know the bike weight etc?
Sorry if i appear dumb..lol
Steve a single rate spring between 7.5kg/mm to 8.5kg/mm will probably get you close
Fork springs want to be around 0.9kg/mm
Old 01-Feb-2009, 23:45   #7
Finally:
A few useful ACU links
ACU Training Course Booking form
http://www.acu.org.uk/uploaded/documents/CTC.pdf
Training Course locations and dates
http://www.acu.org.uk/news/story.asp...a-b247a82cfc27
2009 ACU Licence application form
http://www.acu.org.uk/uploaded/docum...le%20Pages.pdf
2009 Notes to go with above
http://www.acu.org.uk/uploaded/docum...U%20Notes1.pdf
2008 Road Race section of the ACU Handbook
http://www.acu.org.uk/uploaded/docum...ction%2011.pdf
And some out of date but still useful technical info:
http://www.sigmaperformance.com/desmo-due.html
Old 02-Feb-2009, 09:15   #8
Still awaiting the 2009 ACU Handbook, main thing that worries me is any change to noise regs and I'm also keeping an eye on the sizes they allow for the Race numbers.
also just got to say I've had a couple of sets of K-Tech fork springs delivered very quickly by Brook Suspension in Bradford
www.brooksuspension.co.uk
just make sure you give them a delivery address where there is someone to sign for them, otherwise like me you will find the depot of the courier they use is 50 miles from where you work
Old 03-Feb-2009, 17:18   #9
Racekit:
Ramp
Fuel
Transponder
Lap Timer
Gaffer Tape
Electrical Tape
Cable-ties
Tool Box
Socket Set
T-bars
Spanners
Screwdrivers
Rachets
Lockwire
Fuses
Engine Oil
Brake Fluid
WD40
Chail Lube
Superglue
Generator
Battery Charger
Gazebo
Floor Mats
Fluid Catch Tray
Table
Chairs
Lamp
Torch
BBQ
Bike Straps
Extinguisher
Extension Cables
Paddock Stands
Tyres
Portable Stereo
Rider
License
Signature Card
Dogtags
Helmet
Spare Helmet
Leathers
Boots
Gloves
Spare Gloves
Spare Knee Sliders
Water-proof Suit
Spare Visor
Bike Spares
Clutch Lever
Brake Lever
Clip-on Tubes
Foot-pegs
Front Sprockets
Rear Sprockets
Chain
Brake Pads
Grips
Fairing
Nuts & Bolts
Clutch
Crash Bungs
Stand Bobbins
Front Fairing Brackets
Seat Foam
Dzus Fasteners
Old 03-Feb-2009, 17:21   #10
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:05.
