Old 28-May-2004, 19:35
999 with Ohlins settings
Anybody have to hand their front settings on Ohlins forks?
preload, rebound, compression
Old 29-May-2004, 11:09
Come on guys, dont you look at these things?
Old 29-May-2004, 11:37
Errrrrrrr we do look at posts
But 999's with Ohlins? That would be the R then wouldn't it.
Not a lot of us would have any experience of those now would we?
Old 29-May-2004, 12:30
and an S, and there's several of those! And even now some bp's!
Old 29-May-2004, 13:56
Loz's Avatar
Loz Loz is offline
Standard settings per the Owner's Manual ...
Compression 10 clicks from fully screwed in
Rebound 12 clicks
Preload 10mm
There's no charge for this service :P
Old 29-May-2004, 15:22
I know i found the std setting very hard/uncomfortable, and i think so does Everton. which is why i asked.
I have been to the ohlins guy that Mort reccomended, and he set my bike up for me. So ive compared these settings to the std.
Old 29-May-2004, 16:50
Loz's Avatar
Loz Loz is offline
Sorry, I thought you wanted the standard settings!
My own settings will be even less to use to you, as the front feels soft to me as standard!
Old 29-May-2004, 21:56
Andyl Andyl is offline
I have a 999s (Bip) and took it to Harris in Hertford to have it set up. They put softer springs in the forks (one step down) and backed off rebound two clicks. Preload is set at 11 and compression remains standard. At the time I was 13.5 stone and 6' if that helps. These settings feel OK to me but it is still a bit soft at the back and needs one level higher spring on the shock.
Having said all that I still can't ride the thing as fast as it needs me to.
  #9
Old 29-May-2004, 22:45
Cheers Andyl, thats the sort of thing im looking for.
  #10
Old 31-May-2004, 17:58
rottweiller rottweiller is offline
Depending on your weight ideal fork springs if your around 12-13st 8.5 fork springs & 66kg rear spring on the rear set sag @ around 15mm run 16 clicks from max on rebound 15 on compression as a starting point front end you need to set sag @ 25-30mm and adjust rebound & compression to STD settings.
Any additional help visit www.shoxx.biz
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:56.
