Old 08-Jan-2009, 00:25   #1
swannymere's Avatar
Mood: High as a kite!
Ducati 916/955 being stripped
Got an email from a mailing list in the US, they're stripping a 916/955 if anybody is interested?
DUCATI 955 SuperBike - Parts for Sale!
We're kicking off the New Year with a "Bang" - parting out the Ducati 916/955cc Superbike seen in the photos above. This bike is loaded with trick parts - 955cc Race Engine that dyno'ed out at 151 rwhp (on Ferracci dyno), Ohlins R&T forks, Ohlins Race Shock, Ohlins Steering Damper, FBF/Sil Motor 54mm full exhaust, Marchesini Magnesium Race Wheels, 54mm dual-injector throttle bodies with special intakes and much more. The bike was in excellent running condition at the time of disassembly (click on movie link to hear engine running).
THE PRICES SHOWN BELOW DO NOT INCLUDE SHIPPING - shipping will be at cost to your zip code. We ship internationally via USPS, please email us with your location for an exact cost.
Items are sold on a first-paid, first-served basis - we do not "hold" or "reserve" parts for later purchase. This list will be updated online to remove parts as they are sold. The bike is NOT for sale as a unit, it has already been disassembled, so please don't ask "how much for the whole bike", it is not for sale that way. Parts that are not listed below may still be available, and detailed photos of specific items are available on request -email us if you have any questions.
Thank you for your continued support, and we wish you a Happy, Prosperous & Healthy 2009.
Tom
Ducati_Depot
www.ducatidepot.com
PART NAME PRICE $
Wheels & Brakes
Marchesini 5-Spoke Magnesium Race Wheels (17"x 6.0" rear, 17"x 3.5" front) (the wheels use standard axles). Includes Michelin Pilot Race DOT's. Absolutely straight & true w/ no scrapes or dents, but they could use a fresh paintjob or powdercoating. We can have them professionally painted any color you want for $250 more. $1200.00
Brembo 4-pad Front Calipers (65mm) w/ pads $350.00
Brembo Snowflake Front Rotors - 320mm, 6-bolt $200.00
Brembo Rear Caliper w/ pads $50.00
Brembo Clutch Master Cylinder - complete w/ lever & remote reservoir $90.00
AFAM Aluminum Quick Change Rear Sprocket Carrier w/ 37T/520 Sprocket & Cush Drives $175.00
2-Line Front Brake Line Kit $60.00
DiD ERV3 Gold 520 Chain $50.00
Frame & Suspension
Frame - 1996 Ducati 916, gold, includes steering head eccentric. Comes w/ Bill of Sale & Clear Original New jersey Title (no salvage or rebuild) $550.00
Frame - 2000 Ducati 996, black, includes steering head eccentric. Comes w/ Bill of Sale & Florida Certificate of Destruction $250.00
Ohlins Steering Damper $300.00
Ohlins Race Shock $700.00
Ohlins R & T Forks - includes forks only $1500.00
Ohlins Billet Lower Triple Clamp w/ Steering Stem - Black Anodized $350.00
Clipons - L&R $70.00
Swingarm Assembly - Complete w/ hub, axle, rotor, oem sprocket & cush drives $400.00
Aluminum Monoposto Subframe - subframe only, no other hardware included $300.00
Aluminum Race Fairing Stay w/ SPA microprocessor Tachometer, CF Gauge Panel & Wire Harness $300.00
Billet Rearset Footpegs w/ Brake Lever, Standard Shift Lever, Reverse Shift Lever and 3 spare footpegs $300.00
Bodywork
Complete Fiberglass Race Bodywork - Headlight Fairing w/ Windscreen, L & R Fairings, Monoposto Tail Section (no seat, no other hardware included) and Sebimoto Belly Pan. $275.00
Gas Tank $175.00
3-piece Carbon Fiber Airbox $200.00
Carbon Fiber Air Intake Runners - Oversized (mis-matched brands) $125.00
Carbon Fiber Chin Fairing/V-Piece - Sebimoto $100.00
Carbon Fiber Under Seat Tray w/ Oil Catch Tank (race) $350.00
Carbon Fiber Chain Guard $75.00
Carbon Fiber Mono Tail Fairing Support - Sebimoto $125.00
Engine Components
Fast By Ferracci/Sil Motor 54mm Full Carbon Fiber Exhaust - includes headers, manifolds, cf heat shield and crossover (all of the pipes are 54mm) - note that there is a fiberglass patch on the underside of the left canister (see last photo) $1200.00
Ducati Performance Slipper Clutch - complete w/ fresh set of Sintered clutch plates & push rod $700.00
Radiator $100.00
Crankshaft - 916 $125.00
Pankl H-Section Steel Connecting Rods - 916 $75.00
916/955cc Ferracci Hi-Comp Pistons $200.00
Dual Injector Throttle Bodies - bored to 54mm, includes custom velocity stacks $300.00
Single Injector Throttle Bodies - oem $100.00
Corse Race Oil Cooler w/ Stainless Lines $250.00
Clutch Slave Cylinder $35.00
Radiator Coolant Tanks $50.00
Nichols Lightweight Flywheel w/ starter sprag & starter gear $200.00
Electrical Components
Computer (Magnetti Marelli 1.6M - no eprom) $150.00
Power Commander PCIII USB $125.00
Fuel Pump w/ aftermarket metal quick release fittings (male fittings included) $185.00
Wiring Harness - True mono rear and middle (fusebox) section $100.00
Voltage regulator w/ heat shield - 2-phase $90.00
Ignition Coils & spark plug wires $50.00
Air Temp Sensor $25.00
Air Pressure Sensor $25.00
If anybody wants the original email with the photos forwarded to them then PM me.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:55.
