Old 09-Jan-2009, 01:08   #1
Sean K Sean K is offline
Mood: Like a pig in ****
996 Tachometer Problem
I am having to replace the clocks on my '99 996 SPS because of crash damage. I have recently bought a replacement set of clocks from ebay which look in great condition, everything works apart from the tachometer. The seller insists they were working when they came off his bike and I am lost as to why they will not work. I have changed the wiring loom off my old clocks to replace and I still cant get tachometer to work. I know bike loom works because old clocks still work and register despite damage.
The clocks I have bought did not come from 996. Are there different tachometers or circuit boards inside Ducati clocks which may cause this problem?
Old 09-Jan-2009, 01:13   #2
injected injected is offline
injected's Avatar
Mood: Blown away!
I've used tachos from 748's on 996's, but always from bikes with the same 1.6M ECU. I believe your bike has the P8 ECU, so if the replacement instrument came off a 1.6M bike (very likely), that may indeed be the issue.
Old 09-Jan-2009, 22:20   #3
Thanks Injected, very useful information. Where can I find out which bikes have 1.6M ECU and which have P8 ECU so I can track down the right tacho?
Old 09-Jan-2009, 23:08   #4
P8s can be found on the
916 Strada (single injector)
916SP
916SPS
996SPS
also on Corse 955
888 also used the P8 but probably had a different design of tacho
Old 10-Jan-2009, 16:53   #5
final_edition's Avatar
Can you use the gubbin's from this one?
http://cgi.ebay.com/Drehzahlmesser-Ducati-916-996-SPS-rev-counter-racing_W0QQitemZ290287096031QQcmdZViewItemQQptZMot orrad_Kraftradteile?hash=item290287096031&_trksid= p3911.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A1 2%7C39%3A1%7C240%3A1318
Also the seller has advertised it on ducatisiti.
Old 10-Jan-2009, 21:44   #6
Thanks ever so much for your help guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:37.
