Old 15-Jan-2009, 00:01   #1
DUCATI DESMOSEDICI GP9 Technical Specifications
Wroom 2009
Wednesday Jan 14 2009Wroom 2009 DUCATI DESMOSEDICI GP9 Technical Specifications
Engine
liquid-cooled, 90 degree V4 four-stroke, desmodromic DOHC, four valves per cylinder.
Capacity
799cc
Maximum power
more than 200hp
Maximum speed
in excess of 310 kph/192 mph
Transmission
Six-speed cassette-type gearbox, with alternative gear ratios available. Dry multiplate slipper clutch. Chain final drive.
Carburation
Indirect Magneti Marelli electronic injection, four throttle bodies with injectors above butterfly valves. Throttles operated by EVO TCF (Throttle Control & Feedback) system.
Fuel
Shell Racing V-Power
Lubrificant
Shell Advance Ultra 4
Ignition
Magneti Marelli
Exhaust
Termignoni
Frame
Carbon fibre chassis, pressed aluminium swing-arm.
Suspension
Öhlins upside-down 42mm front forks and Öhlins rear shock absorber, adjustable for preload, compression and rebound damping.
Tyres
Bridgestone 16.5" front and rear
Brakes
Brembo, two 320mm carbon front discs with four-piston callipers. Single stainless steel rear disc with two-piston callipers.
Dry weight
148kg
Copyright © 2009 Ducati Motor Holding S.p.A. All rights reserved
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:48.
