Old 29-May-2004, 16:30   #1
DJ Tera DJ Tera is offline
Where can I jack the bike up from?
The bike is currently up on a front stand and an Abba stand (thanks to CK for lending it to me ) but I need to drop the forks, obviously this isnt a possibility while its up on the front stand...
Can I use a car jack under the exhaust pipe or should I remove the exhaust system first and jack it up from under the crankcase?
Old 29-May-2004, 16:36   #2
I removed the horizontal cylinder pipe and manifold and placed a bit of wood over the exhaust port between the studs and put the trolley jack onto that
Old 29-May-2004, 17:34   #3
Problem is to get at one of the bolts securing the manifold to the engine, I need to take the cooler off etc.
Will the bike tip forward if i jack it up from the crankcase?
Old 29-May-2004, 18:24   #4
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Two axle stands either side of the bike & slide a bar wrapped in a rag or a big stick or a very stale baguette under the sump at the front & rest it on the stands......
Well... you get the idea.....
Old 29-May-2004, 19:06   #5
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
What would your mum say to you bolting a lump of 4x2 to the ceiling. This is what I did for Pedro. I drilled 2 holes first then bolted a 9mm ring bolt to it before fixing. Other than that, nick the kids swing from next door and throw a rachet strap over it. Put it underneath the frame close to the headstock and lift away.
Old 29-May-2004, 19:36   #6
Its in the conservatory and the beam wouldnt support a moped, let alone a duke
Old 29-May-2004, 20:00   #7
you dont need to take the cooler off to get at the manifold bolts, use a u/j and extention
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:20.
