Old 09-Feb-2009, 15:01   #1
007 007 is offline
Bikes: 996 Bip
007's Avatar
Mood: CITIUS EST MELIUS!
Exclamation Wanted; Carbon fibre heelplate kit for 996Bp
Hello All,
After a CF heelplate kit for 996Bp as per the below link (or similar);
http://www.worldofqbcarbon.com/produ...916/748916.htm
If anyone has a good second hand unit, please PM me.
Thanks & best regards,
James
Old 09-Feb-2009, 15:04   #2
I've got a set of the Corsa ones:
Do you want those?
Old 09-Feb-2009, 15:17   #3
007 007 is offline
Bikes: 996 Bip
007's Avatar
Thanks TP, I wonder do these cover the exhaust as well or just replace the standard metal heelplates? The kit I was looking at has an exhaust cover and heelplates to replace standard metalwork.
Please let me know what you want for them?
Regards
Old 09-Feb-2009, 16:50   #4
Originally Posted by 007
Thanks TP, I wonder do these cover the exhuast as well or just replace the standard metal heelplates? The kit I was looking at has an exhaust cover and heelplates to replace standard metalwork.
Regards
These cover the exhaust and are larger than the standard metal ones. You can use these with rearsets if you replace the standard footrests and hangars.
It's been so long since I've had a bike with standard footrests that I'm not sure how they go but I'm pretty sure they'll be ok. Maybe someone else could confirm?
£35 incl p+p
Old 09-Feb-2009, 17:35   #5
I've got those on mine - see pic!
Old 09-Feb-2009, 18:17   #6
007 007 is offline
Bikes: 996 Bip
007's Avatar
Thanks for your help.
Old 09-Feb-2009, 19:01   #7
I have a set of carbon heel plates ones to fit the standard footrests, or are yours DP footrests???
Old 09-Feb-2009, 19:32   #8
007 007 is offline
Bikes: 996 Bip
007's Avatar
Hello Chris, my footrests are standard 996Bp, they are not (as far as I know) DP footrests. Will that preclude me from using TP's corsa ones?
Regards.
Old 09-Feb-2009, 20:44   #9
Corsa ones bolt behind the footrest (between the footrest and the frame), so will fit anything.
If you have standard footrests then you can replace the metal heel guards with the carbon ones like Chris posted above.
Old 10-Feb-2009, 18:23   #10
007 007 is offline
Bikes: 996 Bip
007's Avatar
Thanks indeed
