Old 23-Feb-2009, 22:39   #1
YMFB YMFB is offline
YMFB's Avatar
Battery Info Wanted - update
I need a new battery for the ST4, this is probably the third one I have fitted, I know its because I abuse them by riding only occasionally. I have a few weeks until I need it but would like to get a good quality one with high current/power starting ability.
I read some older posts where Rushjob reccomended Varta but that was a few tears ago.
Old 23-Feb-2009, 23:50   #2
Mac-Os Mac-Os is offline
Mood: bemused
Just fitted a PC680 Oddessey battery to my 888. I also cleaned and tightened all the main cables from Battery to earth and to Starter solenoid/starter. Its now no longer a sluggish starter.
These fit the 888 battery tray (I didnt get the Metal Jacket one) with only minor mods (cut the bottom retaining lip off the tray). The new battery seemed well held by the standard top bracket but I fitted a small strap around the bottom for safety.
Old 24-Feb-2009, 10:09   #3
gordonparker's Avatar
MDS
This lot are good for batteries;
http://www.mdsbattery.co.uk/shop/pro...ctGroupID=1039
Old 24-Feb-2009, 10:39   #4
phil_h phil_h is offline
phil_h's Avatar
Odyssey are the absolute best you can get, they hold charge 10 times better than anything else I've ever used, and have a design lifetime longer than anything else.
Old 25-Feb-2009, 08:03   #5
mc31@york.ac.uk mc31@york.ac.uk is offline
I'm not clear why you are getting through so many batteries in the first place.
I understand you are only an occassional rider, but if your battery is on a trickle charger, it shouldn't really make any difference???
Old 26-Feb-2009, 16:52   #6
YMFB's Avatar
The trickle charger is great in the garage at home but doesnt work when Im out also i tend to use it after the event. Should I use the optimate all the time at home ? what happens when im away on the bike ?
I have just spoken to the local Odyssey dealer who need to know
CCA
AH Capacity
size of the battery
If anyone can help with the information that would be great as I dont really have time to strip the fairing off tonight.
Old 27-Feb-2009, 10:18   #7
YMFB's Avatar
Has anyone fitted an Odyssey PCA 680 battery to an ST ?
Old 27-Feb-2009, 14:38   #8
Mine lives on the optimate 24/7. I haven't run it since June last year and on saturday morning it started first push of the button.
I think the Odyssy batteries are a bit bigger than standard ones so you may have a tight squeeze getting it in.
I should add though that leaving it standing for long periods will kill it just as quickly as a regular battery.
Cranking current is not the issue with the St''s anyhow, the problem is with the standard cables between the battery (or solenoid) and the starter. Someone in America does a mod kit with some heavier cables which improves things if you are having issues. Simply fitting a bigger battery will allow the engine to turn over for longer but won't necessarily make it turn over any faster as the cables are the limiting factor here.
Old 27-Feb-2009, 14:43   #9
YMFB's Avatar
rockhopper if it lives on an optimate 24/7 does it start if you go touring for say a week where you dont have the optimate ?
Old 27-Feb-2009, 16:43   #10
If yours doesn't start after a week's touring you need to start troubleshooting your charging system or going through all the wiring/connectors to see if you've got a high resistance joint or cable somewhere
___________^
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:14.
