Old 02-Mar-2009, 13:24   #1
DSC Member MJS MJS is offline
Bikes: None at the moment
MJS's Avatar
Mood: Feeling old...
Alarm removal?
After a couple of weekends of reading and some help on here, plus a couple of trips to Ducati Aylesbury for missing screws etc, I've now got the clutch back in, started the engine, and had a little trip up and down our drive to check brakes and clutch both work.
Now - the only remaining problem is the bl**dy Spyball alarm. Having the battery off for 5 months has caused the key-fob to forget the bike. I've tried the reset procedure in the alarm manual but no joy, also changed the battery in the key-fob but still no joy (Bypassed the immobiliser using the keycode security no. and the key in the ignition).
Everything I've found online says the alarm is cr@p, anyone got any experience of removing alarms or suggestions - how easy etc?
Martin
Old 02-Mar-2009, 16:55   #2
I find Alarms are usually fairly easy to remove, they usually cut into two out of three possible circuits
The three being the fuel pump, starter solinoid and the feed to the coils., other than that they usually tap into the indicators and horn and also tap off the battery feed somewhere.
Old 02-Mar-2009, 19:24   #3
steveknowles steveknowles is offline
Bikes: 998R,D16RR,Bimota V-Due
If it's the spyball specifically made for Ducati I think it's just a plug and play unit, so you just need to find the connector on the loom.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:50.
