Old 11-Mar-2009, 20:37   #1
injected injected is offline
injected's Avatar
Mood: Blown away!
Fixed transponder mounting
I bought a fixed transponder here the other day - can anyone recommend a good place to mount it that will a) work and b) be acceptable to scrutineering? I've always had a clip type one before which allowed more flexibility with mounting....
Old 11-Mar-2009, 21:36   #2
Just mount it on the side of one of the main frame rails - towards the front of the bike, below the front section of the tank. Probably on the RHS of the bike, but makes little difference waht side its on.
Old 11-Mar-2009, 22:01   #3
I always mounted mine on the fork leg in the same place as I mount the bracket for the rechargeable one
Old 11-Mar-2009, 23:05   #4
injected's Avatar
Mood: Blown away!
So how far off vertical can it be and still work? Instructions say it must point down at the track with no metal etc underneath it. Does the orientation matter at all?
Old 11-Mar-2009, 23:08   #5
At Assen all the Dutch guys have them mounted horizontally just like Dallass Ex British Superstock bike does and that crosses the line a bit quicker than our DD bikes do, so a small amount off the vertical shouldn't cause a problem
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:37.
