Old 12-Mar-2009, 13:01   #1
wolverine wolverine is offline
wolverine's Avatar
Mood: custard
power comanders?
does anyonr know if a 996s power comander will fit on to a 916?
is it just a matter of changing the data/powercurves etc?
Old 12-Mar-2009, 13:27   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I would think it would be the plugs not sure if the 916 & 996 share the same plugs, but you could always hard wire it.
Old 12-Mar-2009, 14:04   #3
injected injected is offline
injected's Avatar
Mood: Blown away!
Yes, they are interchangeable. I've had the same unit on my 97 748 and 2001 996 with no issues. As you say, you just need to reload the database with the appropriate table, or better still set the unit up on a dyno.
Old 12-Mar-2009, 21:23   #4
Andy748 Andy748 is offline
Bikes: Ducati MS1200 & 916 track bike
Andy748's Avatar
As said above it should work fine, I used the same 748 PC3 when I fitted my 916 engine. You will need to budget for a custom map as there are no default 916 maps available for some reason.
Old 13-Mar-2009, 12:52   #5
wolverine's Avatar
Mood: custard
cool! straight back to ebay then!!!
thanks
Old 13-Mar-2009, 12:54   #6
wolverine's Avatar
Mood: custard
i thought i saw the maps on the dyno jet web pages, maybe i was looking at the wrong ones, or a could jusat get it dyno-ed properly, do you know if the maps are lisenced? could a just have a copied one of another 916?
Old 13-Mar-2009, 13:36   #7
injected's Avatar
Mood: Blown away!
Yes you can copy from another 916, but for the sake a few quid why compromise? If you copy the map, there's always the nagging thought that the other bike may have had a different chip in the ECU, different air filter, different pipes etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:02.
