Old 23-Mar-2009, 12:33   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Clutch push rod
Anyone knowing the length of the above on a 1999 moster 600? Since I have put the dd bike back together I just cannot disengage the clutch fully. It's rock hard half way through the lever travel.
Missed already 3 sessions a at brands today, hopefully the change of coil should see me out on track once before lunchtime...
Tonio
Old 23-Mar-2009, 13:54   #2
I can check when I get home
Have you replaced the O-rings on the push-rod as they harden and can restrict the travel as they refuse to move through the hole in the casing
Old 23-Mar-2009, 18:27   #3
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Are the clutch basket groves and clutch plate teeth worn I had mine sticking and failing to disengage because of that. 4D
Old 23-Mar-2009, 19:33   #4
Tonio600's Avatar
I forgot to mention that this is after I replaced my standard clutch MC (the one with square reservoir attached) with a gold one with remote reservoir.
So the problem might well come from the MC I found on eBay, will first swap them back and let you know.
Old 23-Mar-2009, 21:41   #5
Doubt if its the difference in M/Cyls
Which Slave cylinder have you got, Should be the early type and they use a M/Cyl with a 13mm Diameter Piston which is the same as 916s etc later 748/996/998s went to the Slave with the Star shape bit on the end of it and they had a 12mm Diameter M/cyl
Old 23-Mar-2009, 22:17   #6
305mm for the rod in my 1999 M600 Engine (early type Slave cyl)
313mm for the rod in my 2003 M620 Engine (later type Slave cyl)
Old 23-Mar-2009, 23:36   #7
Tonio600's Avatar
Cheers Kev
Will check mine asap. It doesn't seem to be a problem with the MC or the SC as I have swapped tried several of them already.
