Old 02-Apr-2009, 00:16   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
bearing removal
Hello
Anybody have any tips on removing the bearings from the swinging arm?
I guess the obvious would be to use a socket and lump hammer,
but would ideally like to use a puller of sorts. Any suggestions?
Also would you advise replacing the large green o-rings on the concentric hub?
TopiToo
Old 02-Apr-2009, 21:14   #2
748adam 748adam is offline
748adam's Avatar
for the bearings i just warmed the arm up infront of a gas fire to get enough heat into it, then tapped it out with a socket and it near enough fell out. (burnt my hand on the arm though haha) as for the green O-rings, im just cleaning them up with water then using rubber grease and using them again.
probably of no use but i have a copy of a genuine ducati manual if you need any info, i also have a full parts list with exploded diagrams and part numbers if you need it
Adam
Old 05-Apr-2009, 23:31   #3
Bikes: 748ish . .
Hello 748adam
all done now thakyou
you have a PM
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
