General Motorcycles only
Old 02-Apr-2009, 23:55   #1
Question Clutch Pressure Plate Bearing Info
So I need a new bearing for the clutch pressure plate as I can't drift the old one out as you can't see/get to the outer race from the outside.
I've noted down the bearing details:
SKF 6201 - 2RSH2 / C3VT127
ITALY 18B 05 198D - EXPLORER
So what does that all mean?
I know SKF is the manufacturer and that it's a "6201 2RS" bearing but they appear to come in all different sizes ... so which one do I need?!?
Old 03-Apr-2009, 00:03   #2
Aha! Found it with some Googling...
"Ducati Clutch Bearing, genuine SKF double shielded 'Explorer' precision bearing. C3 precision class. Packaged in Singles. These high quality bearings made in Italy are the same product as fitted to Ducati motorcycles. 32mm Diam, 12mm ID, 10mm wide, and once fitted this bearing will give many years of prolonged service. Be aware of cheaper imitations, genuine bearings should always be used."
So I need a SKF 6201 2RS 32mm Diameter, 12mm Internal Diameter and 10mm wide.
Looking on ebay, I can buy a "Ducati Clutch Pressure Plate Bearing" for £7.99 + £3 postage.
Searching for the bearing itself, I can buy the right one for 99p + 60p postage.
Hmmm ... I wonder which one I should buy ...
Hope this helps anyone else!
Old 03-Apr-2009, 00:06   #3
Bearing Codes Explained:
RS - Rubber Shielded one side
2RS - Rubber Shielded two sides
Z - Shielded one side
ZZ - Shielded two sides
C1/C2/C3/C4/C5 - Internal Radial Clearance
Old 03-Apr-2009, 01:15   #4
They're getting cheaper
http://www.ducatisportingclub.com/sh...highlight=6201
