General Motorcycles only
Old 04-Apr-2009, 21:59   #1
Question about Power Commander adaptability
I was wondeing (and will probably try it) if its possible to use my Power Commander 3 USB from my 998 on a 750SSie.
Not having studied the injector pulses from either bike I was wondering if the pulse sent to the injectors of the 750 by its 1.5M ECU differs from the Pulse sent to the 998s injectors by its 5.9M ECU.
I can't see as the amplitude of the pulse will differ of the frequency as I would expect this to be linked directly to engine revs.
Anyone else tried something similar
Old 04-Apr-2009, 22:17   #2
Scooter916's Avatar
Mood: Hmmm Conference season
Kev I think TWPD may be able to help on this one, Im sure we supplied him with a PC that wasnt listed for his bike but it worked.
Im sure he will be along soon enough.
Old 04-Apr-2009, 22:34   #3
A lot of the PCs have specific connectors to suit the model they are intended for, the PC2 on my 750SSie has the big suare connectors allowing it to plug directly in-line with the ECU connector.
My 996 PC3 (serial connection) has a plug and socket that mates up with ons for the throttle body harness.
The 998 PC3 USB conects in-line with the injectors, so it should be possible to connect it to quite a few other models in this way
Old 16-May-2009, 20:28   #4
Well the answer to my own question looks like its a YES
I have just had my Class A DD bike thats using a 1.5M ECU from a 750SSie running with a PC3 USB from a 998 connected up with throttle position wire from the PC3 tapped off the Yellow wire that runs between pin 11 of the ECU and the TPS.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:53.
