Technical - Help or Info - NON Motorcycle
PC's, Internet etc. Cars, or how to fix that leaky radiator - in here please!
Old 14-Apr-2009, 20:28   #1
injected injected is offline
injected's Avatar
Mood: Blown away!
No smilies on DSC?
For some reason I can't insert smilies into posts on DSC - I can add one to the thread header, but there's no option to insert them in the body of the posts.
Am I missing something?
Old 14-Apr-2009, 20:35   #2
Dementor's Avatar
Just type them
Ducati Snells of Alton : >>
Dementor Site :>>
Sponsor of DD Riders
Old 14-Apr-2009, 20:38   #3
just not a happy place
Old 14-Apr-2009, 21:55   #4
You need to use the Advanced form when replying (seen by pressing the 'Go Advanced') button at the bottom of the screen.....then you will see a small toolbar on the top of the form with the 'smilie' icon clearly visible.
I think about 6 images (or smilies) is the current maximum per post.
When creating a new thread you should see the advanced form already
Regards - Frank
Old 14-Apr-2009, 22:20   #5
injected's Avatar
Mood: Blown away!
I don't have that toolbar Frank - unless I'm being stoopid. See attached
Regards - Frank
Old 14-Apr-2009, 22:28   #6
There's a list down the bottom (see pic) leads to this page:
http://www.ducatisportingclub.com/mi...do=showsmilies
Old 14-Apr-2009, 22:57   #7
injected's Avatar
Mood: Blown away!
Thanks, that works. Is that the only way to do it? Seems long-winded to cut and paste from that page every time
Old 14-Apr-2009, 23:06   #8
Took me a while to figure this one out
Injected - Your screen dump holds the answer actually, you must be using the 'Reply' buttons the left hand side of the page.....
These actually reply to THE THREAD rather than to individual posts (there is a difference, trust me )
I'm pretty sure if you use the Reply buttons in the posts on the RHS of the screen you will get the 'Go Advanced' option & be able to get the smilie drop-down...
(There is an option to choose the advanced editor straight away via the Edit Options link in your control panel / Quick links above)
Cheers - Frank
Old 14-Apr-2009, 23:35   #9
Actually, the answer is this...
From the top menu, select User Settings and then from the Control Panel select Edit Options.
At the bottom of this screen, change the Message Editor Interface drop-down box to show "Enhanced Interface".
Click Save Changes and the next time you reply to a thread, you'll get a quick list of smilies and a full drop-down list in the menu too...
Old 14-Apr-2009, 23:40   #10
injected's Avatar
Mood: Blown away!
Antony solves it! Thanks, that's been bothering me
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:32.
