Old 21-Apr-2009, 11:26   #1
greggyboy greggyboy is offline
header pipes
Hi all
My header pipes are grounding out on my ss going round corners. Not sure what the previous owner took them off. Does anybody else have this issue? I was thinking of getting an under seat system done, however money is tight. Will a standard ss header pipe system solve the problem.
thanks
greg.
Old 21-Apr-2009, 11:52   #2
paynep's Avatar
Mood: Wet wet wet
Assuming that you have a 2-into-2 system, the Monster 620 ones can ground out while I don't think anyone has had a problem with 620Sport ones. Dunno about Monster 600 though?
Also I never had a problem with 750ss headers on road or track and I think I've got a set of 750ss ones which will fit a 600ss if you need a cheap fix
Alternatively if you only have a 2-into-1 std system the back of your bike is too low or the spring is too soft or the shock is knackered...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:51.
