Old 29-Apr-2009, 00:11   #1
Wanted: UK Beam deflector for 916-style Headlight
My 748 needs a UK deflector plate for the headlight, apparently!
I've managed to cut and weld the EU one that was in there, but it's a bit of a mess so really needs replacing.
Does anyone have a broken headlight unit they no longer want?
Will exchange for beer tokens
Old 29-Apr-2009, 14:12   #2
RickyX RickyX is offline
RickyX's Avatar
Antonye,
I took out my EEC one, drew round it and made a template, then cut a new one out of a Coke can to a mirror image.
Been through at least 4 MOT's like that...no problems and only cost 50p.
I gave the Coke to my boy as I hate the stuff!
SORTED!!!!!!!!!!
R
Old 29-Apr-2009, 18:00   #3
Mood: Come on spring!!!
headlight
mate i have a uk light with cracked lens no longer needed let me know if you want it.
chris
Old 30-Apr-2009, 00:28   #4
Hi Chris,
I'm only after the deflector.
You can disassemble the light:
- take the two dome nuts off the back and pull off the metal cover
- there are 4 screws holding the projector unit into the casing, undo these
- undo the 2 bigger phillips screws and the projector will come apart
- inside is a small bent plate held in place with a phillips screw - that's what I need!
If you have this, let me know as that's what I'm after...
Old 30-Apr-2009, 17:35   #5
light
Ok mate will get it in bits saturday and get back to you
Old 30-Apr-2009, 17:40   #6
Super, thanks!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:53.
